Old 12-01-2009, 04:33 AM   #1 (permalink)
Increasing Accelerator Pedal Resistance
Is this a plausible way to avoid accelerating more rapidly than intended?
Of course there is the decreased acceleration ability = decreased safety argument. But when you consider that a 1999 Hummer does 0-60 in 15.5 seconds, it seems like all one would have to do is preserve the ability to accelerate faster than this.
I was thinking of something along the lines of a wedge of rubber/silicone/foam etc. under the pedal.
So what do you think? Is mechanically increasing accelerator pedal resistance a reasonable idea?
Old 12-01-2009, 06:59 AM   #2 (permalink)
I'd say get a scangauge and learn how to drive more efficiently is a much better option.
Old 12-01-2009, 07:28 AM   #3 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
What works real well is an additional spring on the accelerator linkage...set up so that you can feel extra resistance near the throttle position that you typically need to hold speed at say 55 mph. Acts much like using a vac gauge..except that you don't need to watch it. You can easily overide the spring when needed. Just has to be done right so there is no chance of your accel pedal sticking.
A block of soft rubber might work also.
Advantages? It works and doesn't cost a lot. Cost effective.
You naturally develop the habit of driving for mpg.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 12-01-2009, 09:12 AM   #4 (permalink)
5.4L Econo Box
Jim Allen's Avatar
Plugger - '05 Ford F-150HD 4x4 XL
This is a good point.
I find that cars/trucks with electronic throttles are hyper-sensative and the pedal slopes programmed in are designed to give more throttle response with less pedal movement, making them very touchy. I'm working on reprogramming that in my rig, but in the interim, have been thinking about some way to increase tension on the pedal.
With my F-150, if you take a deep breath, you can effect the throttle. Sneeze and you're doing 90! Seriously, most times I can manage good throttle control, you have to work pretty hard at it. Too hard, IMHO.
Jim Allen
The Frugal Four Wheeler and Farmer
My ultimate goal is not necessarily the highest mpg but to make my trucks more efficient configured as I need them.
Old Reliable '86 Ford F-250HD 4x4, 6.9L diesel
Red '00 Honda Accord Coupe, 3.0L V6, automatic
The Plugger '05 Ford F-150HD 4x4, Regular Cab, 8-ft bed, 8,200# GVW, 5.4L V8, automatic, 4.10:1 ratios, 285/70R-17D tires
Old 12-01-2009, 11:28 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
the block probably belongs under the brake pedal
Old 12-01-2009, 11:36 AM   #6 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Check this thread out.
http://ecomodder.com/forum/showthrea...ack-10269.html
Pressure Gradient Force
The Positive Side of the Number Line
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 100 12-30-2022 06:25 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
New tires for the truck--rolling resistance and mpg savings 07b2300 EcoModding Central 14 07-01-2008 12:29 PM
