Old 06-25-2009, 05:33 PM   #11 (permalink)
yah-yah
Originally Posted by tasdrouille View Post
Phil, I would be inclined to think that you are half right on this one as the optimal diffuser's angle is dependant on the diffuser's lenght. Hucho's book showed 2 diffusers of different lenghts. For the longer one the optimal angle was around 2.5 degrees, while for the shorter one it was closer to 3.5 degrees.
Fabrio posted an image from Hucho's work on this here
tasdrouille,sorry,I'm brain dead and very late getting back as I just looked at the images.I never paid much attention to the short diffuser,as I've never done one,and somehow,what I remember from Hucho's summary was that the 2.5-degree angle was preferred for low drag.So you're more correct and it is conditional,based on long/short form. I'll take the heat for anyone who labored to fab the "wrong" diffuser.Good eye! If I get to be a liability here at EcoModder,you all can just park me out on an ice flow where I won't be able to hurt anyone.
Old 06-25-2009, 09:35 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
It seems that no matter how many times I cut this darn diffuser, it's just not long enough...
Old 09-23-2009, 07:51 PM   #13 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
what are those metal rods that serve as the skeletal backbone to your bellypan? Where did you get them? I'm going to start a bellypan myself and I dont know if i should create a framework like you did or just tack it on as-is.
I'm kinda lazy so I'll likely just tack it on as-is.
crx coroplast belly pan finished! paulwelkins EcoModding Central 28 05-15-2015 05:24 AM
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
2009 skyline belly pan pics lovemysan Aerodynamics 9 04-02-2008 05:02 PM
