Old 11-20-2010, 05:30 AM   #1 (permalink)
Belly pan for trucks
How do you deal with air flow under a truck? No matter how you smooth the air out from the front to the rear axle you still have the rear axle in the way. Do you deflect air out from under the truck with trailer skirts?
Name:	under truck.jpg
Old 11-20-2010, 06:40 AM   #2 (permalink)
MrMiata's Avatar
78 Olds Cutlass - '78 Oldsmobile CutlassSupreme
Big Red - '10 Toyota Venza AWD
Thumbs up Truck underbelly
First you turn the truck over........
With a solid rear axle, I would build the underbelly rearward to the axle, leave space for the suspension travel & axle then start behind the axle and continue to the bumper.
That's my starting point and I'm stickin' to it.
Have A Great Day, Bob
Old 11-20-2010, 01:03 PM   #3 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I just got mine done today...
My belly pan thread over at ToyotaNation.com...
I lowered my belly pan about 4½" below the frame so it's pretty close to the bottom of the rear differential.
This is what it looks like from the front going to the back...
From the back going to the front...
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
landsailor (06-19-2011), SVOboy (11-23-2010)
Old 11-22-2010, 02:22 AM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I just got my second best ever gas mileage with a 26.58 mpg at 65mph. Previous run last year fer the same time period and same drive was 20.49 at 70mph.
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
3-Wheeler (11-24-2010), aerohead (11-22-2010), SVOboy (11-23-2010)
Old 11-22-2010, 07:50 AM   #5 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
looks pretty good bamzipow, but might I make a suggestion and overlap the panels from the rear to the front so there is no chance of an edge flapping and parachuting.
~Mike
Old 11-22-2010, 03:40 PM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
They actually butt up against each other and I've taped some seams down. Thanks fer the suggestion.
The engine bay panel still needs to be revamped since I put in the cross members. It's short about 2½"...
Old 11-22-2010, 07:30 PM   #7 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
at least you have a bellypan, Im still trying to find materials to make one for my ranger, along with how Im going to go about it in the first place.
unfortunately, there wasnt many (if any) coroplast signs around me during the elections, so I could grab any up. but even then, Im not real comfortable using that type of material, so I think Im just going to stick with my original plan of using lightweight aluminum.
~Mike
Old 11-22-2010, 10:21 PM   #8 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I initially used 1x2 wood and luan to build a test belly pan before I moved on to my current choice of materials. I wanted to learn what was going to be my best method to approach my goals fer my belly pan. One of them was fer minimal fasteners to be removed fer access. Another was adjustability...I can raise or lower the belly pan with some PVC pipe and longer/shorter bolts.
I would say give some thoughts to some "test" materials before you move on to sheets of aluminum. You don't want to find out yer design wasn't optimal fer yer material choice...
Old 11-22-2010, 11:37 PM   #9 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
good point
I think I will see if I can hit a recycle center and see if they have some coro.
~Mike
Old 11-23-2010, 12:01 AM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
That does look great bamzippow, do you have your own thread about building it here?
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Belly pan how-to brucepick Aerodynamics 55 06-10-2013 09:15 PM
Free belly pan in kansas city! lovemysan Aerodynamics 16 07-02-2010 10:22 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
