EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Bellypan near exhaust? (https://ecomodder.com/forum/showthread.php/bellypan-near-exhaust-22115.html)
bandit86 06-01-2012 05:44 PM
A lot of you guys are using cloroplast for belly pans, do you leave the area near the exhaust out? Or cover that part with different material? Or insulate the pipe?
Gealii 06-01-2012 07:16 PM
I have seen where people have cut out openings for the exhaust, and put down material. It was not on the actual exhaust piping but the exhaust itself. Others have used metals to make it more durable then chloroplast and do more to protect things, such as the transmission, from anything that goes underneath the vehicle. I'm thinking about doing an Aluminum belly pan for the added protection as being on the highway blocked in to where i could not do anything semi's have blown tires which go underneath and cause transmission bills.
oil pan 4 06-01-2012 07:28 PM
A few people on here have used heavy wire mesh or screen for the places that get up next to the exhaust.
BamZipPow 06-01-2012 11:42 PM
It's not cloroplast or chloroplast... ;)
http://en.wikipedia.org/wiki/Corrugated_plastic
If you experiment with Coroplast...you will see it might melt when it's within 1" of the exhaust system... ;)
I protected my Coroplast with some aluminum flashing. :D
mcrews 06-02-2012 06:53 AM
Guess you could do a search....
Or go to the second link in my signature!
Otto 06-08-2012 01:55 PM
Corrugated plastic - Wikipedia, the free encyclopedia
Also, could face or dress the coroplast near heat sources with aluminum foil adhesive tape. At hardware store, comes in rolls like duct tape. Protects the coroplast edge, dissipates heat from any hot spots.
Also, you could fill the holes cut in coroplast for muffler clearance with aluminum window screen, which lets the holes breathe and vent heat, but still smooths the airflow of the passing slipstream.
BamZipPow 06-08-2012 04:53 PM
At a thickness of 2mil, I'm not sure that would do much. Even aluminum foil would be better than that... ;)
mcrews 06-08-2012 06:14 PM
http://i678.photobucket.com/albums/v...pgq45115-2.jpg
screen
http://i678.photobucket.com/albums/v.../mpgq45117.jpg
Sven7 06-08-2012 08:47 PM
I zip tied some crushed pop cans to the coroplast belly pan right under the muffler and it works just fine. All you want to do is get a couple cm of air between the hot part and the 'plast.
If you don't, it'll just melt a hole. No biggie in my experience, but I wouldn't do it intentionally.
orbywan 06-17-2012 04:04 PM
I followed the Honda Insight guy's lead and wrapped my diesel exhaust in fiberglass insulation anywhere it was within 4 inches or less from the coroplast, it worked perfectly. You have to remove the paper backing so all you have is the fiberglass but to my surprise, no melted coroplast. I held it in place with aluminum tape at first and realized the adhesive might let go when it gets hot so I tied it all up with bailing wire. A year and about 2,000 miles later, no problems.
orbywan
