Originally Posted by fastflyer
Other:
This flap is for lift but primarily to create high pressure on the front of the cooling stack. With a crude converging duct
I dont know what rig this is , duse it have a vent on/in the hood /finders ? Or dose the air pass through the coolers then dump back out on the pavement into the low pressure zone created behind the flap?
Aerohead you called it proformance orientated cooling at the cost of a front without holes . Add a lever turning the flap into a damper to close the opening and callit active aero. Or a temperature controled grill block.
----z
Kach22i Less blue area with a splitter, blue is lift from what I can tell - it has a negative number.
1 line above ⬇️
The underside of the splitter also generates low pressure (blue) and downforce
Under the splitter the blue is suction (negative numbers pull on a surface at a right angle ) toward the ground aka downforce. The bigger the gradient surface side to surface side the stronger the effect. The blue at the top of the wind screen on the lower example is suction toward the sky aka lift caused by separation resulting from too sharp of a radius (sudden 10-15°change of wind screen angle)
Dam Vs splitter
Dam has lots of blue (drag aka rear force) on the rear .
Splitter focused this drag energy into a smaller confined space, larger gradient and a different orientation now vertical and downforce. The blue also dissipated much faster returning to green (0 neutral) with the chin1/4of the rendering Vs 1/2 with the dam only.
Catch 22 your finger sliped I'm not ragging on you it just surprised me with your wealth of knowledge how much you've helped me with these things over the years. For you make the misinterpretation means we are human, it takes a computer to truly screw up.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
