Old 01-01-2008, 07:59 PM   #1 (permalink)
eta
cheap, light-weight EV battery?
I just researched the "Braille No Weight Racing Battery" as a very lightweight battery to start an ICE car. I found it to be a re-badged and over-priced Deka, made in Reading, PA, normally sold as a motorcycle and ATV battery. Deka is evidently leading the battery industry in power/weight ratio, and "Big Crank" (bigcrank.com) claims that this is a "deep cycle" battery. While it is conventional lead-acid, it uses "absorbed glass mat technology" so it can be discharged completely hundreds of times without damage, and can also be recharged rapidly, etc. Its specs are fantastic. For example, the ETX 14 weighs only 11.5 lbs and is only about 6" X 4" X 6" and yet the guys on VWVortex.com say it starts their cars in cold weather with no problems! And the Deka ETX 14 sells for only $60 on Bigcrank.com !! So if it can indeed also be used on electric and hybrid cars as a deep cycle battery, why isn't everyone using it? It would save hundreds and hundreds of pounds, take up far less space and is cheap! Am I missing something here?
Old 01-01-2008, 11:07 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Not really.
http://forum.ecomodder.com/showthrea...=3701#post3701
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 05-13-2009, 11:15 PM   #3 (permalink)
2004 Prius Owner
lectruck's Avatar
14 amp hour battery, you would need a lot of them to get anywhere!
Old 05-14-2009, 04:17 PM   #4 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Lesse, at ~.1kWh usable per battery and 11.5lbs per battery, a 10kWh pack would weigh ~1150lbs, last about 8000 miles, and cost about $5000 at $50 per battery. Right now LFP group buys are around $350/kWh, so $5000 will get someone at larger ~14kwh pack that weighs about 300lbs, and will last at least ~90000 miles. Lead acid is fine as a starting battery because it's mature and what people know, but the way things look other chemistries like LFPs may even take that title from LAs.
Old 05-14-2009, 07:38 PM   #5 (permalink)
I'm very noobish but the one thing I've found that EVERYONE in the EV world agrees on is that there is no such thing as a cheap good battery. And the second thing everyone agrees on is that the battery is the most important part of the parts list.
I would love something cheaper but I'm willing to spend the money upfront to keep from having to do it several times from trial and error.
Old 05-15-2009, 01:00 AM   #6 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
those batteries could be good for drag racing, as they might last a quarter to half mile.
Nissan and Toyota's New Year's resolutions: LOSE WEIGHT MetroMPG General Efficiency Discussion 18 01-16-2015 04:57 AM
Feeling bad about your bike light? AndrewJ Alternative Transportation 9 07-07-2009 02:34 AM
Toshiba enters the lithium ion battery market SVOboy Fossil Fuel Free 6 03-21-2009 02:28 AM
Cheap way to patch a tube? SVOboy Alternative Transportation 19 12-15-2007 05:28 AM
Oil weight question: 0w30 or 5w20? MetroMPG EcoModding Central 4 11-25-2007 08:57 PM
