Old 07-14-2008, 10:44 AM   #1 (permalink)
SaturnSl1 - '00 Saturn SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ford Ranger
CRX HF - '89 Honda CRX HF
90 day: 51.59 mpg (US)
Permanent Grill Block
I went to look at my grill block last week and it was deteriorating quite a bit with all of the rain lately. It was made out of two layers of foam board and wrapped in tape around the 75% of the grill.
I decided to go all the way when I started thinking about a permanent solution.
I started with putting cardboard behind the grill and then inserted three 1 1//2" PVC pipe sections into the existing grill for venting. Then I sprayed the entire grill with gap seal. It's like insulating foam, except doesn't cause the same problems that other people have had on this board. Once the foam cured, I cut it to shape using a hacksaw blade. Filled in gaps with more foam, cured, cut again.
Once I had the shape I wanted I went for a test drive. Turns out 3 little openings were't quite enough for cooling the engine. I was getting temps around 210F on the highway and 220F+ with stop and go traffic. Went home, cut 4 more holes and went for another drive. 7 holes seems to be the right number for my Saturn. No overheating.
After all the foam was cured, I started putting Bondo over everything. I still have quite a bit of sanding to do before I paint it with factory spray paint. I'm hoping to get it so close that you can only tell from a few inches away where my paint job started.
Not done yet, but the pictures should give a pretty good idea of where I'm at.
As a side note: the test drive I did was after I installed the belly pan.
ID:	1158   Click image for larger version
ID:	1159   Click image for larger version
ID:	1160   Click image for larger version
Old 07-14-2008, 06:21 PM   #2 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
I really like the smiley face!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 07-14-2008, 06:34 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Raysp30 -
Wow, you are going for it!
PS - Better make sure that the dog-catcher doesn't see it until it's done, or (s)he'll try to have it put down for having rabies!
CarloSW2
American Solar Energy Society
Old 07-16-2008, 02:04 PM   #4 (permalink)
I seem to remember something about letting air escape out of the engine through ductwork that would patch into the front wheel wells. Would that be more important to do since I also have a belly pan on there?
I think it was Bajoos that commented on that a week or so ago. If anyone knows what I'm talking about, do you have pictures of your set up?
Old 07-16-2008, 05:50 PM   #5 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
My car has a 6" diameter opening connecting the engine compartment to each front wheel well through which the driveshaft runs, so I didn't have to do any mods (other than installing the underbody panel) to divert the air out through the front wheel wells.
aerocivic.com
Old 07-17-2008, 10:42 AM   #6 (permalink)
Basjoos - I looked at every one of your 96 pictures that you posted a while back. I don't suppose you could post #97 when you get a chance so that I can see what you're talking about?
Old 07-30-2008, 10:22 AM   #7 (permalink)
Completed Grill Block
Okay, I finally got the paint to come in. It's not perfect. You can see where the mod began, but you can't really tell from more than 4 feet away.
I had to make the center opening a little bigger than what I started with. It now runs at a very consistent 195F-200F on the highway. She gets a little warm when in a traffic jam or heavy city traffic, but with my manual fan override switch, it hasn't been a problem. I'll start cooling it down when it creeps past 210, so the fan never has a chance to automatically kick on at around 226F.
ID:	1325   Click image for larger version
ID:	1326   Click image for larger version
Old 10-04-2011, 12:30 AM   #8 (permalink)
Reloadwin's Avatar
Silver Prius - '08 Toyota Prius
90 day: 46.37 mpg (US)
Looks good.
Grill Block Poll. Ryland Aerodynamics 33 08-03-2017 11:30 AM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
My try at a partial grill block bhazard Aerodynamics 15 04-30-2008 10:09 PM
