Old 10-05-2011, 05:46 PM   #1 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
Thinner differential oil for RWD car? ('06 Miata)
I recently sold my '06 Jetta TDI DSG (127k mi) and bought an '06 Miata Touring 5-speed (19k mi). The Jetta's DSG started slipping, and it seemed to be in danger of needing a very expensive replacement transmission. I've wanted a Miata for years, and now I have one!
On the Ecomodder forum, I've seen lots of really interesting experiments and experiences with manual transmission oil. However, I haven't seen as much discussion about thinner differential oil. Has anyone done any experiments with this?
I wonder if something like GM Synchromesh or Volkswagen G52 could be used in my Miata's differential?
I don't drive the Miata hard at all...my favorite thing about the Miata is that it's incredibly fun to drive without driving fast or accelerating hard.
Old 10-05-2011, 05:56 PM   #2 (permalink)
Both my vehicles are rear wheel drive and the thinnest I would try is a synthetic 70w80 or 70w85.
Gear Lube - Oils, Fluids & Additives - Oils, Fluids & Sealer - SummitRacing.com
There is even a 75w60 weight, kind of different. Too bad it only come in 5 gallon buckets at a cost of $220.
1337 (10-16-2011)
Old 10-05-2011, 06:14 PM   #3 (permalink)
Good idea! Is this an example of what you have in mind? Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MTL 70W80 GL-4 Gear Oil According to the Red Line specs, this oil has 10.6 cSt viscosity at 100 degrees C.
Old 10-05-2011, 06:27 PM   #4 (permalink)
I would be much more comfortable using a 70w80 weight MT oil in a diff compared to something possibly way too thin like ATF or GM synchro oil.
If I ever decide to swap out my GM 10 bolt rear in my camaro for something else I will be sure to fill it with ATF and drive it for a while just to see what happens.
Old 10-05-2011, 06:45 PM   #5 (permalink)
I believe that the 65+ mods list does mention thinner diff oil as a possible way to reduce driveline losses. How thin you can go is definitely a very good question, one I don't know anything at all about. I've only ever owned cars with transaxles, where the transmission and diff share a single oil supply.
-soD
Old 10-05-2011, 07:20 PM   #6 (permalink)
Regency - '94 Chevrolet S10 LS
90 day: 29.2 mpg (US)
yea i had the same question because im about to change mine and its never been changed so ive been told... (220,000 miles) I cant see it never being changed but i guess i will see when i actually change it. I just need to figure out what im going to change it to..
Think im just going to go with the 75w-90 synthetic
The Following User Says Thank You to regency For This Useful Post:
1337 (10-16-2011)
Old 10-05-2011, 08:21 PM   #7 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
I used to own a 1968 Volvo 144. I changed the differential oil in it to 75W90 synthetic. I don't know what I drained out, but it was definitely thicker than the 75W90 I put in.
Then the car developed a loud gear rattle at part throttle at 65-70 MPH, my normal long trip speed at the time. I believe that that rear end needed a slightly thicker oil. Any mileage improvement was very minimal, well under one MPG.
Hypoid gears need a minimum oil viscosity to prevent metal to metal contact.
The Following User Says Thank You to JRMichler For This Useful Post:
1337 (10-16-2011)
Old 10-05-2011, 08:34 PM   #8 (permalink)
Depends on the gears really, and how the were setup, also how much backlash they have at time of oil change.
If mines starts to make noise i will go back to 80w-90 and consider it a flush of the old fluid
Old 10-08-2011, 01:47 PM   #9 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Redline ger oil has an actual viscosity in the 50-60 range when hot. Works great even in high horsepower applications.
Check out bobistheoilguy forums for way better information than I can provide.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
The Following User Says Thank You to dremd For This Useful Post:
1337 (10-16-2011)
Old 10-09-2011, 11:24 PM   #10 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
One problem you are going to have is not so much the viscosity as it is the additive package. For a diff, you'll want a GL5 add-pack.
Syncromesh, Red Line MTL, Amsoil MTF and the like are GL4. I don't believe any of those are dual rated GL4/5 ... but some 75W-90s and 80W-90s are.
For really thin rear-end gear oil, I might try this stuff:
Red Line Synthetic Oil - Gear Oil for Differentials - 75W85 GL-5 Gear Oil
or:
Red Line Synthetic Oil - ShockProof® Gear Oils - Lightweight ShockProof®
The Superlight Shockproof is likely too thin for proper durability.
I think with a Miata, though, you're #1 enemy is wind resistance. I love my convertible, but it's an affront to the aero gods.
--- Bror Jace
The Following User Says Thank You to Bror Jace For This Useful Post:
1337 (10-16-2011)
