Old 11-20-2014, 01:54 AM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Oh wow!
So, I completely forgot, since I got my insight I haven't been calculating the 4.6 offset on my speedo, so it turns out I have been doing a lot better mpg wise then I thought! Woo-hoo!
Old 11-20-2014, 02:04 AM   #2 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Woohoo!!!
Now update your fuel log so your signature can show 2.3% ABOVE EPA!!!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 11-20-2014, 02:05 AM   #3 (permalink)
Furry Furfag
Originally Posted by jeff88 View Post
Woohoo!!!
I was under EPA ratings before updating, now I'm over
Old 11-21-2014, 06:29 PM   #4 (permalink)
This is a 91 Honda! HDY!
HDY! 91 Honda - '91 Honda Civic Base
How does one do those calculations? GPS says my Civic shows 5 MPH slower than actual.
Also, could this be corrected with a larger/smaller tire? I'd love for it to be correct
Old 11-21-2014, 06:41 PM   #5 (permalink)
Furry Furfag
Well i just did mine because my car has tires that are 4.6% bigger, so for every 100 miles I travel, it's 104.6.
Old 11-21-2014, 06:44 PM   #6 (permalink)
Can you elaborate? For every 100 miles on the odo, you actually go 104.6?
So, are bigger tires better for MPG?
Does that make the speedo read faster or slower than actual?
Old 11-21-2014, 07:11 PM   #7 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Just because the speedo does not read correctly does not mean the ODO is off as well. My Focus reads 2mph high but the ODO is spot on. Verify miles traveled with your GPS before doing math that might not be needed.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 11-21-2014, 08:02 PM   #8 (permalink)
Good advice, I'll check this as well
