Old 04-04-2010, 02:20 PM   #1 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Testing covering up grille area on 2000 Camry today.
Removed front upper grille. Using old tee shirt I stretched the fabric tight over the existing grille and shot it with several coats of old spray paint. Total costs basically zero.
What I aim to test is whether or not I can operate without this grille open.
As I live in Maine avg temps are a lot lower the many more southern states and almost all (98+%) of my driving is hwy) I believe it will be fine.
If cooling temps stay in range I then will make a permanent mod by covering this with dacron and getting it total flush with bumper and hood.
Pete
Pics later
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
GM Testing What Ecomodders already know: The Grille Block markemmanuel Aerodynamics 16 02-17-2010 09:15 AM
Chevy AVEO: Adding grille blocks and air deflectors Thymeclock Aerodynamics 11 01-02-2010 04:39 PM
Blocked my lower grille today Magister Aerodynamics 3 11-10-2009 09:13 AM
2000 Caravan grille block: is it for me? Christ General Efficiency Discussion 1 04-15-2009 09:49 PM
