Old 02-28-2009, 04:28 PM   #1 (permalink)
lightfooted leadfoot
red - '91 honda civic hb dx
90 day: 42.59 mpg (US)
Red Too - '99 Toyota Taco
Better shape to the air dam
I've just put on a cardboard template on red, 91 civic. Wouldn't it be better to have the bottom edge leading aft? Or is the object to divert air from the bumpy undercarriage. The dam looks very un-aerodynamic. I know ideally pointy front/smooth undercarriage, but having not been very successful finding the 4x8 abs I want (hint, hint, source please) I not quite to the undercarriage.
Old 02-28-2009, 06:06 PM   #2 (permalink)
The purpose is to not have as much drag from the components hanging down. If you had a smooth flat bottom you might actually want to direct air under
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 05:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 02:49 AM
Effects Of Air Dam (Ford F350 pickup) Big Dave Aerodynamics 59 05-06-2012 02:32 PM
Free: spring-loaded air dam in San Bernardino, CA Ptero Aerodynamics 6 10-21-2008 10:19 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
