Old 01-26-2012, 04:37 PM   #1 (permalink)
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
Metal Mesh Belly Pan?
I've heard of some cars (from Mercedes, I think?) that have metal mesh on the underbody, to act as a belly pan of sorts. In a way, it makes sense. Because the mesh is slicing through the air edgeways, instead of hitting it full-face. Thoeretically, that would make it act as a "virtual solid" aerodynamically.
I doubt the mesh would be as effective as a solid surface, though. But it should be better than nothing. And expanded aluminum mesh can be had at the hardware store pretty cheap (and lightweight).
The idea here wouldn't necessarily be to build a complete belly pan from metal mesh, just the parts that are near hot spots, like the exhaust system.
Has anyone tried this yet? A search didn't yield anything.
Old 01-26-2012, 05:05 PM   #2 (permalink)
A bellypan should be rigid. If you don't get the mesh very tight it will sag and flap in the wind.
Old 01-26-2012, 05:38 PM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
He mentions expanded metal which is no more flimsy than normal sheet metal. I'd be interested whether this would aid or detriment the aero. I'm sure the mesh itself isn't very good with airflow. Paging Phil!
Old 01-26-2012, 06:53 PM   #4 (permalink)
mesh
If you go all the way to the back of Hucho's book,in the chapter on Numerical Analysis,he makes mention that air cannot support a load of any kind and will simply deform,attempting to reach equilibrium.
When the Big Dogs do 3-D CFD on cars,they will actually 'panel the wake',setting up the spherical vector coordinates of the wake as if it were a solid body to enable the inviscid flow protocals to function.Quite a challenge when there is no 'a priori' knowledge of how a theoretical cars wake will actually behave.
All this suggests that it requires a solid surface to alter airflow.
********* Here's the caveat for a belly pan though.If the rear valance is low enough to trap and pool dead air below it,for the entire length of the cars underside,a permeable membrane might aid in damping pressure oscillations underneath there.
There may be research published on such a thing.I don't know.So far,automakers are using solid panels,shielding heat sources.
If you have the inclination and want to do some sweat-philanthropy,do the mod and let us know.
You will need an exquisite baseline database for the vehicle for which to compare before and after.
Old 01-26-2012, 11:05 PM   #5 (permalink)
Expanded metal isn't really all that flat though.
Old 01-27-2012, 01:19 AM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
you mean somethiong like this?
before
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Blacktree (01-27-2012)
Old 01-27-2012, 01:27 AM   #7 (permalink)
mcrews's Avatar
in one of the middle pics, you see that the belly pan also is under the rear axle so there was no air trapped in the rear bumper.
It helped thsat i am running a IMPUL full body kit which gives me 2 extra inchs lower.
the middle is just screen material. as the air passes next to it it acts as a solid surface.
In the back I used the preformed screen. I had to tilt it down just a hair!
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-27-2012, 02:34 AM   #8 (permalink)
The screen is a good idea for places where you always end up running over tumble weed in the road.
Old 01-27-2012, 03:09 AM   #9 (permalink)
Lead-footed Econewbie
Ceffy - '97 Nissan Cefiro 25 excimo
90 day: 25.21 mpg (US)
Demio - '07 Mazda Demio Sport
90 day: 30.99 mpg (US)
Mesh would resist fluttering in the wind somewhat, due to it being open. Also solves any heat build up problems.
But how much would it shape airflow? Is it really almost as effective as a solid smooth surface? Or is it closer to having nothing at all?
I though about strategically placing holes in a belly pan to try release pressure differential.
Old 01-27-2012, 08:01 AM   #10 (permalink)
Where/why would you have pressure build up around the bellypan?
