Old 06-17-2011, 02:31 PM   #11 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Originally Posted by tjts1 View Post
There is some ACTUAL news about biofuels today.
http://www.nytimes.com/reuters/2011/...imes&seid=auto
I saw that blurb about the subsidies, so the question is does this mean that ethanol will be eliminated from gasoline or is it just the subsidy only.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 06-17-2011, 02:37 PM   #12 (permalink)
The article explains it. They're eliminating both the subsidy for US grown corn ethanol (45c/gallon) and the tarrif on imported ethanol (54c/gallon). The E10 and E15 rules are not changed. Chances are the bill will be changed before it goes into law. It will probably end up as a reduction of the tarrif/subsidy system rather than an outright elimination.
Old 06-17-2011, 02:54 PM   #13 (permalink)
Saw that, was going to do an edit.
Old 06-17-2011, 05:06 PM   #14 (permalink)
You should see the local yocal comments on the ethanol subsidy- 99% misinformed. The REQUIREMENTS for ethanol blending are unchanged, so the fuel will be unchanged, so there will probably be some combination of higher prices at the pump and/or lower cost imported ethanol being used.
Oh, and Haiti is a prime example of people allowing their gonads to completely disregard the local reality of resource supply. 12 kids/ea and they literally eat dirt...
Old 06-17-2011, 05:29 PM   #15 (permalink)
It will only make a 4.5 cent rise in E10 prices, E85 will go up 38 cents per gallon. E85 sales will go down, E10 users won't even notice.
Old 06-17-2011, 06:17 PM   #16 (permalink)
As if most of us can even find E85.
Old 06-17-2011, 07:45 PM   #17 (permalink)
There is no shortage of food on the planet, there is probably close to a billion people on this planet though that have no money to buy food. If food prices were high enough there would be no food resources diverted to energy sources, its economics 101.
Old 06-17-2011, 08:22 PM   #18 (permalink)
I just wanted to get a thanks from Frank, LOL.
I wonder how alcohol would work in one of Mazdas SKYACTIV engines with 14 to 1 compression ratio.
regards
Mech
Old 06-17-2011, 08:47 PM   #19 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Doesn't bother me. I never put alcohol in my vehicles.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 06-17-2011, 09:15 PM   #20 (permalink)
Hey BD, you're about to break 1000 posts!
