Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-16-2011, 11:33 AM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
ELVIS is knocking
What is this? elvis recipe
"Electrochemical Liquid Vortexing Ionization System"?
Old 12-16-2011, 01:12 PM   #2 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
The Following User Says Thank You to jakobnev For This Useful Post:
California98Civic (12-16-2011)
Old 12-16-2011, 08:40 PM   #3 (permalink)
Cyborg ECU
Originally Posted by jakobnev View Post
hahahahahahaha!!!!
Old 12-16-2011, 09:39 PM   #4 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
No,no, they have real science. Look at the pretty drawing DIY Fuel Ionizer for real cheap. Really works.
Isn't this what NASA uses ?
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 12-17-2011, 12:07 PM   #5 (permalink)
Cyborg ECU
In the comments, here's a response that looks like it could have come from members of ecomodder.com:
makenakai -
I looked at your test results.
There's only one baseline measurement, so it's really not possible to statistically know the true baseline values, but the ELVIS tests have an average CO% of 0.86 and a standard deviation of 0.25%. This excludes the two measurements with 0.00 CO%, as those should almost certainly be taken as outliers. The baseline CO value is 1.7 standard deviations from the average ELVIS CO measurement.
Given the variation in your data, if you test 50 times you would expect 5 results that are at least 1.7 standard deviations from the mean. Typical statistical significance of a difference between the two conditions - with and without ELVIS - would be assigned if the distance is 1.96 standard deviations or more.
Regarding the hydrocarbons, your baseline is only 0.32 standard deviations from the mean of the ELVIS tests. By all measures, the two conditions can be statistically assumed to be identical.
Do you have more baseline data? That would help firm up the interpretation - it could even help your case.
Old 01-14-2012, 07:40 PM   #6 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
from Jason's link:
the outbound fuel stream is spun into a high speed vortex that braids the liquid inwardly into a higher energy imploded state.
Head asplodes!
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
