Old 11-24-2018, 02:10 PM   #11 (permalink)
compressed
Not to be a stickler for detail,but there is no air compression until you reach 250-mph.You can't exceed the local barometric pressure at the forward stagnation point.
Old 01-16-2019, 09:34 AM   #12 (permalink)
IS - '92 BMW E36 318IS
90 day: 38.73 mpg (US)
90 - '95 Honda Civic EG4 VX
90 day: 43.44 mpg (US)
New mods installed!
Oem part from a 325tds.
Itīs has been modified to prevent air from passing under the radiator.
Partial covered lower grill.
Leaving the same width as the radiator. That is, it prevents more air from entering. Also I covered the left air intake.
Do you have any suggestion?
Old 01-16-2019, 01:53 PM   #13 (permalink)
compression
As I understand it, at speed (while traveling down the road) there is an air pressure build-up at the front of the car as the air is compressed.
A lot of that pressure is at the lower chin because the air at the top part of the front has an easy escape path up and over the hood, there is acceleration of the air and lowering of pressure when this happens.
Meanwhile the air attempting to escape under the car is not allowed to expand or escape and remains compressed under high pressure.
Look at your radiator, all those little fins.
Do you think air is going to easily pass through if there is no pressure behind it to back it up?
Or do you think higher pressure air has a better chance of being pressed though it?
NASCAR Computational Fluid Dynamics (CFD) Surface Pressure Plot
https://robrobinette.com/S2000Aerodynamics.htm
Short answer: Upper grille block is the norm around here.
Technically,there wouldn't be any compressive effects until around 250-mph,when the car would enter transonic flow.
At low speed,the air at the forward stagnation point would have the highest pressure,as it has zero velocity.
