Old 02-17-2011, 01:50 AM   #1 (permalink)
Rick323's Avatar
Black Cruze - '18 chevrolet cruze ls
90 day: 38.28 mpg (US)
The Ram - '22 ram 2500 tradesman
90 day: 12.35 mpg (US)
Block Heater?
I recently installed a block heater in my Tacoma for fuel mileage, not for ease of starting. So I was wondering what other people do in regards to pluging in their vehicles for fuel mileage. Do you always plug in your vehicle or is there air temperature (40-50+/- deg F) that you stop pluging it in?
Old 02-17-2011, 05:57 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Any amount of heat added to the engine helps reduce post start-up fuel consumption, not to mention wear and emissions.
Mine was installed before the winter, but I intend to use it year-round. In the warmer part of the year I may keep it on for only 1-1.5 hours, instead of the current 1.5-2.5h.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Rick323 (02-17-2011)
Old 02-17-2011, 11:30 AM   #3 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I use mine year round as well. the only time I don't use it is when the outside air temps are expected to be ~140df then I won't need the block heater.
Old 02-21-2011, 02:22 PM   #4 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
I plug mine in at tempuratures below 10C [50F] and have it on a timer for 90 minutes only, on work days, on other days, I just plug it in about an hour before I leave. So far the things I've noticed are that the cold engine lite goes off 30 - 60 seconds sooner, at -20C, the scan guage WT first drops from about 35C for about 30 seconds then rises to 55C in about 1 minute on the highway. I have not tried to quantify how much fuel I save.
Old 02-22-2011, 09:16 PM   #5 (permalink)
Driving the TurboWeasel
Mine gets started about 6-7 hours before needing the car. Then the big iron lump of a FSP engine gets up to 85-90*F at 15*F outside temperature. And it stays there or higher during my short-tripping mornings for work since the 150 or so lbs of iron making up my engine is thoroughly heat-soaked.
I'll likely use it year-round with reduced times in the summer for better fuel economy year-round.
2012 Chevrolet Cruze Eco 6MT
Old 02-22-2011, 09:17 PM   #6 (permalink)
It only needs an hour or two of plug-in time.
Old 02-22-2011, 09:25 PM   #7 (permalink)
I tried an hour or two, and it raised the temperature to 50*F when it was 15*F out. That temperature plunged rapidly upon engine startup.
My electric bill hasn't noticed much of a change either way. It's a 400-watt Kats coolant heater plumbed into the lower radiator hose on the opposite side of the system from the thermostat.
