Old 05-02-2012, 12:07 PM   #1 (permalink)
Audi A4 - '00 Volkswagen Jetta GLS
Generic Crossover - '10 Honda CR-V EX
Question Block heater?
I make a lot of short trips and my engine doesn't often run on its ideal temperature. I'm considering purchasing an engine block heater, would this be a good place for a noob eco modder like my myself to start?
Old 05-02-2012, 12:24 PM   #2 (permalink)
Yes.
Old 05-02-2012, 06:32 PM   #3 (permalink)
It won't do much good if your short trips take you to places where you can't power up the block heater. Also consider that the heater itself requires a capital outlay to purchase it, and the amount you will spend on electric power for it offsets the potential savings on gasoline. Those are the reasons why I don't have one.
Old 05-03-2012, 08:17 AM   #4 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
I found that by insulating my engine compartment, my engine stayed warmer for much longer. I'd recommend starting there. I used some foil covered bubble wrap looking stuff from my local Home Depot, aluminum duct tape, and cardboard to construct. Didn't take long to make, either.
Old 05-03-2012, 11:32 AM   #5 (permalink)
Iexpedite's Avatar
G-sux (Sold) - '06 Pontiac G6 GT
90 day: 28.3 mpg (US)
Conda (Sold) - '92 Honda Civic VX
90 day: 51.52 mpg (US)
Honda - '21 Honda Accord Touring
90 day: 28.43 mpg (US)
I have been looking at purchasing an oil pan heater for my VX. It's warm here right now, but that doesn't stop my lifters from chattering in the morning. If I pre-heat synthetic oil I should be able to stop the chatter and get a faster warm-up. My car hasn't been reaching "lean burn" temps until I am halfway to work. Throw in a grill block and it should heat up within a 1/4 mile.
Old 05-03-2012, 01:23 PM   #6 (permalink)
If it's below freezing, the best strategy is to do a full radiator block. Make it out of cardboard and such a way that it is easily removable. You will need to remove it after the engine reaches operating temp, so you are not running too hot.
block heater
