Old 10-09-2012, 01:19 PM   #1 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
My 94 VX
I am going to start this thread for my new car, a super clean 94 VX with 112 000 miles. This car is replacing my heavily modified Neon, found here.http://ecomodder.com/forum/showthrea...ods-20741.html
The VX will stay basically stock looking. It will get a grill block, maybe a belly pan, and possibly a kammback, although it will have to be factory looking.
I really owe a huge thanks to an ecomodder member here, Brian, 1carnut. I bought the car from him, and this past friday a friend came with me a d we drove down and picked it up. Brian was extremely helpful, especially with the fact that the car was being exported/imported to Canada, and he took care of a bunch of the necessary paperwork for me. The car is awesome, it's incredibly clean and obviously well taken care of. There are a few rust spots that I have to address, but really nothing serious. The car also has a well done, subtle injector kill switch.
I really want to say thank you again Brian!
I only have a few pictures of it so far. Here they are.
Kumho Solus tires, 155/80/13
I will get some more pictures later, as well as the interior once I am done installing my stereo.
Old 10-09-2012, 01:58 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Better put anti-rust treatment on the list too!
Nice car. Lean burn + MPGuino will be lots of fun and will return some stellar economy.
Old 10-09-2012, 02:07 PM   #3 (permalink)
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
You're welcome! I'm glad it went to someone on the forum and you seem like you truly appreciate it. Good luck with it and anxious to see the progress and some awesome numbers.
The Following User Says Thank You to 1carnut For This Useful Post:
2000neon (10-09-2012)
Old 10-09-2012, 02:40 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
dang that's clean wheres the rust spots?
I would definitely coat the underside with something
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 10-09-2012, 02:42 PM   #5 (permalink)
Inside the doors, rockers, fenders too. If you plan to keep it for more than a couple of years, it's worth it to take it to a place like Krown or Ziebart, etc. It'll probably cost about 140.
Old 10-09-2012, 02:46 PM   #6 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
Dude your el camino is ****ing nice!!!!!
Old 10-09-2012, 02:47 PM   #7 (permalink)
Jakins's Avatar
Your civic is really nice too haha
Old 10-09-2012, 03:45 PM   #8 (permalink)
2000neon's Avatar
Thanks guys! I just spent a bit more time on some rust areas, mostly doing the shock towers under the hood right now, then I will get into to the more visible areas. None of the rust is too bad so I have high hopes for this car lasting me a long time.
I was going to use leftover truckbed liner in the fenders and under the rockers, then a healthy oil spray, but I changed my mind. My dad uses a waxy coating stuff on his tractors, both sprayed and brushed on, it's not too thick, dries very solid and because it's wax based it is completely moisture resistant. We have used it on a few of his tractors and the stuff is downright incredible, but expensive. However, to me, and how nice this car is, it is well worth it.
If I feel it is still necessary, I have a buddy who works at Krown who said he can take care of it inside the rockers etc. I plan to take rust control and prevention very seriously, rust is the only thing I see for me not having this car for years to come.
I took the care with the El Camino, and I've had it for 7 years, I hope the VX will be the same.
Old 10-09-2012, 08:03 PM   #9 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
I wish you a very happy ecomodding/hypermiling with that VX.
Old 10-09-2012, 08:36 PM   #10 (permalink)
I'm confused by your user name. Didn't take long did it?
I'm totally in favor of you stepping back 6 model years.
