Old 09-20-2012, 11:57 PM   #1 (permalink)
Unhappy Bms
Hi,
I have a cell module assembly with built in LiFePO4 2S2P cells. I wanted to use the BMS controller that you have.
However, I cannot achieve the 2.5 - 4.0 V across the terminals since there is a 2S2P cells built in it. How can I use the BMS controller?
Can I modify the BMS controller to enable me to take an input of 7.5V nominal? Or can I use 2 boards for each cell ie, 1 board for each 2P cell?
I appreciate any help in this...thanks.
Afida
Old 09-21-2012, 08:48 AM   #2 (permalink)
What BMS controller are you talking about?
2s2p, bms
