Old 02-04-2023, 01:04 PM   #51 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 25.04 mpg (US)
Yeah, I'm hoping he's saying cargo carrier, because a trailer ain't gonna work.
Hitch mounted cargo carrier is exactly how I'd implement something like this, so I could easily remove it if needed.
Old 02-04-2023, 01:15 PM   #52 (permalink)
....because a trailer ain't gonna work
There is a fine line betwixt the two.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
BamZipPow (03-18-2023)
Old 02-04-2023, 01:38 PM   #53 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Was going to get something like this and use dibond for the boat tail
The Following 2 Users Say Thank You to Phase For This Useful Post:
freebeard (02-04-2023), Isaac Zachary (02-11-2023)
Old 03-07-2023, 02:03 PM   #54 (permalink)
Phase's Avatar
Did a Julian Edgar style box cavity as a test on back roads. Car felt less draggy. Wasn’t really able to flare the side inwards to reduce wake size and no hard measurements. But I was surprised it stayed attached even after 60 mph.
ID:	33501   Click image for larger version
The Following 3 Users Say Thank You to Phase For This Useful Post:
aerohead (03-09-2023), BamZipPow (03-18-2023), freebeard (03-07-2023)
Old 03-07-2023, 04:32 PM   #55 (permalink)
If you still have the part, you could slit the bends halfway and overlap them to add some taper.
And add a difusser section to stiffen the bottom edge.
Old 03-07-2023, 05:36 PM   #56 (permalink)
Phase's Avatar
yeah the hard part is trying to bend all of the angles inwards. may have to practice with some notebook paper at home or something lol
Old 03-07-2023, 09:54 PM   #57 (permalink)
Pie cuts:
Old 03-09-2023, 10:25 AM   #58 (permalink)
'cavity'
Technically, it's not a box cavity until it has a 'bottom.'
That open underside is polluting the pressure recovery of the top and sides, compromising performance.
If you had access to General Motors' contracted B-Roll video of their land speed record Impact/EV1 land speed record 'Yellow Ferret' box-cavity, you'd have a perfect example of what to build.
Cd 0.137, and 183-mph, in 1993!
freebeard (03-09-2023)
Old 03-09-2023, 01:28 PM   #59 (permalink)
Phase's Avatar
Well the goal before having a full proper boat tail is to do a smoother under tray and work on a permanent rear diffuser
Even though it’s not a perfect box cavity, the roof lije did extend our and go a little lower past the spoiler, and the sides created much harder separation edges. A lot of newer Toyotas use some “ extended” separation edges below their tail lights. No idea how much those effect things since they aren’t the whole rear body. And then the Kia EV 6 uses a weird mid center box cavity shape thing, almost like the Audi a2 box cavity
Either way, I wasn’t going for a box cavity for this test. I was just trying to test out the angles and attachments and extensions for the actual boat tail mod down the line. I “ felt” lower drag and better coasting though with this giant cardboard shape, so it must be doing something versus the stock rear. I got some crazy looks from the 3 total cars that drove near me though
Old 03-09-2023, 02:54 PM   #60 (permalink)
Follow the bumper seam line down to a radius along the wheelwell flare.
Maybe the problem was calling it a 'Julian Edgar style box cavity'.
