Old 09-23-2015, 10:24 PM   #11 (permalink)
Okay... so this was a total failure haha. I got the dc-dc converter installed tonight. However, I really just didn't think this through. I cut the wires right in front of the ignition coil... but those don't carry a constant 12V. The ECU fires the ignition signal to them as needed. Well, the dc-dc converter just won't work under those conditions. It needs constant 12V. The engine wouldn't even fire up with the dc-dc in the circuit. Looks like I'll have to boost the voltage to the ECU if I want to do this. That probably means I'll need a higher rated dc-dc to fully supply the power the ECU needs. I'll look into that.
So, it sits like this with some electrical tape around it. I'll solder it back up and get some shrink warp on it later on.
However, I still have this dc-dc converter and I have another just like it laying around. They're rated for 80W, and I think they'd probably do a good job running power to the headlights. So, I think I'll use them there instead.
The Following User Says Thank You to Daox For This Useful Post:
redpoint5 (09-23-2015)
Old 09-23-2015, 10:39 PM   #12 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I think the positive feed to the coil is constant with the ignition on, you should be able to boost that.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Daox (09-25-2015)
Old 09-23-2015, 10:44 PM   #13 (permalink)
Perhaps that is it. I just put my voltmeter on the two terminals and got nada with the ignition on. I figured there is a mosfet in the ECU that fires the 12V signal. I can't imagine there being something on the other side of the coil where you'd have to deal with the 40,000V.
Old 09-29-2015, 12:29 AM   #14 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
have you checked that your headlights are getting the voltage you do have? Do you know what the voltage drops are to your lights? In effect I boosted my headlight voltage by about a volt by adding relays to the ground/control side of the circuit.
Old 09-29-2015, 12:54 AM   #15 (permalink)
Yes, the OEMs will run 10 amps through 10 feet of 14 gauge wire for your head lights and you will get some voltage drop.
Running a fused wire straight off the battery or alt and slaving the old wiring to run a relay will brighten them up a lot.
(not a problem if you have LEDs)
