07-13-2010, 12:01 PM
Has anyone converted/modified a 2003 toyota echo?
i'm an owner of a 2003 toyota echo.. just wondering if anyone out there is pushing mpg on that veh at all.. and what mods are done?...
i'm pushing over 40mpg presently .. i'm aiming for 50mpg at this time
bone stock .. with tires at about 37psi... & syntetic in the tranny
-steveo
07-13-2010, 12:08 PM
There was as guy on another site pushing his well above 50 if I recall correctly doing mainly lower speed driving. I think he even hit 60 a few times. Very good car and a nice engine in it too. He didn't modify it at all though except tire pressure and maybe a grill block.
07-14-2010, 12:07 PM
Engineering first
Would you consider getting a repairable NHW11 Prius (2001-03), the manuals and getting it working? I know of one in North Carolina for a good price.
We had both a 2001 Echo, 34 MPG with automatic, and still have a 2003 Prius, 52 MPG with automatic. Getting a used Prius and fixing it up can give you a 50+MPG vehicle with a little more room than the Echo, much better cornering, and a lot of options for improvements (check out Orange4Boy's postings.)
Many of the NHW11 Prius sustainable maintenance issues have been identified and corrections found. A 'fixer upper' is one way to learn the technology.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
07-14-2010, 04:22 PM
In persuit of Efficiency
55 mpg at 55mph in 2001 Echo (no mods)
I am an owner of a 2001 toyota echo with no mods except scangauge. Its a 2 door with manual transmission and 95,000 miles on it. My Echo loves 45 mph in 5th gear, at that speed it only sipss about 0.59 gallons per hour giving me 60+ mpg.
At 55 mph I get somewhere between 52 to 56 mpg
At 65 mph I get between 40 to 45 mpg
Above 70 mpg the milage goes down to 34 mpg
If I turn on A/C subtract another 5 to 7 mpg from above numbers.
All of the above readings are on a flat ground with minimal wind and no passangers.
It is absolutly crazy how changes in elevation affect milage. Even on very small gradients (0.5%) the milage drops 10 mpg or more.
The most important aspect of high efficiency driving in my car is to maximize coasting time, if you have a manual transmission like me letting off the gas pedal shuts down fuel to the engine and boosts milage. Also try to get to the highest gear as quickly as possible, driving 45 mph in 4th gear gives me only 44 mpg while in 5th I get 60+
Good luck
07-14-2010, 04:32 PM
Engineering first
I had to get one my wife would drive: four doors, electric locks, and automatic transmission.
Above 70 mpg the mileage goes down to 34 mpg
Here is my NHW11 performance curve and some data points:
I also found after driving the Prius that the Echo's higher center of gravity required slower speed on the turns.
Bob Wilson
05-04-2011, 03:18 AM
I also have an echo and I regularly get around 51-52 mpg (manual). Do you have a manual? If so, how did you replace the tranny fluid. I've been wanting to do this for some time..
JD
03-20-2012, 01:18 PM
Echo mpg
The Toyota Echo is one of my favorite cars to work on. I have a 2000 Echo with a manual trans and 255,000 mi. I get 520 to 540 miles to a tank, when before I would get 380 to 420.
Here are my mods: Heated fuel line, NC magnets on fuel line, pulstar spark plugs, and a K&N filter. I try to drive conservatively too.
I tried a HHO kit with a manual EFIE and was getting 50 mpg, but the EFIE went bad and I stopped using it.
I also have a Buick Park Ave getting 36 mpg (tank average)
06-11-2012, 02:09 PM
EcoModder user Echo-Francis owns a 2005 Toyota Echo Manual. We actually get around 60 to 67 MPG with that car. We have a lot of mods on it, grille block, a complete belly pan, wheel covers, nose shaped front bumper, no power steering belt, LED lights, side skirts, wheel spats, and wiper deflector.
We run with syntetic Mobil 1 5w-30. Irridium Parkplugs, new michelin defender LRR tires, and a new air filter.
We use DWL, DWB, P&EOC, we drive at 50 mph on hwy.
Check out our thread for more informations or discussions.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
