Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 03-29-2008, 07:15 AM   #1 (permalink)
Treadmill Motor (candidate for e-bike?)
The treadmill here at work is opened up for maintenance so I took a look at the motor. Here are the specs:
3HP Continuous Duty @ 13vDC / 2672watts
It is 11" long x 4.5" dia, with a 1.5" shaft.
There is a also a fan connected to the end opposite the drive shaft.
So would this be a decent bicycle motor?
S.
Old 03-29-2008, 08:09 AM   #2 (permalink)
90 day: 51.82 mpg (US)
Except for the fact that it's way big, and probably pretty heavy (25 lbs?), the specs are fine. In fact it's likely overkill for an e-bike. Run that at 24 volts and you'd have a silly fast machine.
Old 03-29-2008, 02:57 PM   #3 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Yep, what Darin said.
Overkill, especially considering that the biggest electric scooter motors (good for +35mph) are just over 1000 watts.
Oh, and Ben Nelson's motorcycle uses a 4hp (continuous) Etek motor.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 03-29-2008, 04:26 PM   #4 (permalink)
It IS a little long, but it could be centered with a jackshaft arrangement.
Maybe for a motorcycle then? Obviously treadmills get going hellu fast, but I would have thought that their motors would be made for high rpms as opposed to the torque needed to get a bike moving.
S.
Old 03-29-2008, 04:58 PM   #5 (permalink)
It'd probably work well for a low speed motorcycle or moped type of EV.
Old 03-29-2008, 05:05 PM   #6 (permalink)
The Civic - '00 Honda Civic DX
90 day: 37.05 mpg (US)
Sounds like a perfect candidate for very a fast ev-kart to me.
Old 03-29-2008, 05:50 PM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
What brand of tread mill is this on? just in case any of us wanted to get one for our selves.
If you ever used that motor at full power it would draw 205 amps, that is alot of amps! you would need 2/0 or 3/0 wiring, that is .40" to .46" diameter, so with smaller wire size you are never going to get full power out of that motor, so basically you are going to have a motor that will never be over loaded, and should never wear out, with that you should be able to up the voltage and be fine with 24V battery and speed controller.
Old 03-29-2008, 08:33 PM   #8 (permalink)
HotRod's Avatar
HotRod - '94 Geo Metro Reg
90 day: 58.89 mpg (US)
Can you post a pic of that?
I am not a Hippie...I am cheap.
Old 03-30-2008, 05:31 AM   #9 (permalink)
I think its been put back together, but Ill try to get a pic of it.
Either way, the next one that breaks down, the motor is mine!
S.
Old 04-02-2010, 03:45 PM   #10 (permalink)
ElectricZX2 - '98 Ford ZX2 Cool Coupe
90 day: 140.91 mpg (US)
Any progress on this? I was thinking about doing something similar...Are you sure it isn't 130 volts? i have a treadmill motor that says 2.5 horsepower, 130 vdc, 18 amps. Its a PM motor so you would need a speed control right? some smaller motors r 90 volts. High voltages are used to keep the current down.
Summer FE options - Scooter, bike assist, etc friedlbug Alternative Transportation 16 02-20-2009 01:41 AM
Bike riding at night - pointers. AndrewJ Alternative Transportation 9 03-30-2008 02:24 AM
The Ultimate Commuter Bike NoCO2 Alternative Transportation 13 02-29-2008 12:45 PM
lack of Bike Racks (for parking/locking to) Lazarus The Lounge 4 01-16-2008 01:49 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
