Old 06-29-2009, 09:33 PM   #1 (permalink)
Thumbs up Braking on deceleration
I'm probably all wet but I was wondering if you could program your controller to actuate (electric clutch?) an alternator on decelleration or brake application?
The idea being to assist in braking and also help recharge the system 12v battery.
I don't know if an alternator would provide enough drag to be worth it. What do you think? Jim
Old 06-29-2009, 11:35 PM   #2 (permalink)
I suppose you could do a horsepower to watts conversion to estimate the size of the desired "load".
Old 06-30-2009, 01:00 AM   #3 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
The down side of this is that in a hard stop, brakes process over 1,000 HP. It can be hard to get a battery to accept charge at that rate. On the plus side, most braking can be done at less than 100 HP, especially if you plan it, and even if the system is inefficient, to keep it light, it is better than a total loss.
Old 06-30-2009, 01:40 AM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Would a capacitor accept that large of a charge that quickly?
Seems like if you could get a cap that would handle it, you could use that last bit of braking to aid in your take-off, in the case that you have to... without using any actual pack power.
Just a thought, although probably not a good one.
Old 06-30-2009, 01:57 AM   #5 (permalink)
It is a fine idea. A capacitor could buffer the charge going into the battery, as originally proposed, or help out a traction battery. Being more efficient than the battery, it could not only accept braking overloads, but handle all the stop and go work more efficiently.
A cheaper option might be mechanical storage. Springs are heavier than capacitors for the same energy, but for a 30-0-30 system, they still would not weigh a lot.
Engine braking and stop lights Piwoslaw Hypermiling / EcoDriver's Ed 73 07-28-2024 12:18 PM
Why is 'hard' braking bad for fuel economy ? Cd Hypermiling / EcoDriver's Ed 36 09-08-2014 12:08 PM
Do-it-yourself regenerative braking? Bearleener EcoModding Central 25 02-10-2013 10:35 PM
Deceleration Alternator bbjsw10 EcoModding Central 26 10-03-2011 03:07 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
