Old 03-23-2009, 03:47 PM   #1 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Crr ~= 0.0102, about right?
Using the roll-down test spreadsheet and data gathered last summer, I was able to load up the spreadsheet for Cd and Crr. However, I already had the Cd, 0.29, from earlier Toyota sources. So all I had to seek was Crr and that came in about 0.0102. Is this pretty much what other folks are seeing?
The spreadsheet pretty much asks for about 60-70 seconds of data but I only had 40 seconds. As a rough approximation, it seems to fit the higher speed parts close enough.
Yes, I'll go back and gather some fresh data next weekend with longer roll-down intervals. Just I thought I'd ask if 0.0102 seems about right.
Thanks,
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 03-23-2009, 03:58 PM   #2 (permalink)
That sounds about right. From the figures I've seen Crr goes from ~.07 to ~.12. Unfortunately, I can't recall where I've seen those numbers.
Old 03-23-2009, 05:41 PM   #3 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Wikipedia has numbers for Crr, and I have seen at least one guy's numbers from a coast down test on instructables. You can see how he did his test here, and use his spreadsheet if you like. According to co_driver, you can include Cv (coefficient of viscous [skin] drag) also, and just approximate it at 1 Newton per Meter/second. You can see his equation in this thread if you like. Like I said, you have to approximate the skin drag, since the solver function will blow the skin drag number way out of proportion.
Old 03-23-2009, 11:02 PM   #4 (permalink)
90 day: 51.82 mpg (US)
The author of that instructable estimated his '92 Metro with 145/r12 (I think) tires inflated to 45 psi: Crr = .0106
