Old 04-01-2010, 02:20 PM   #11 (permalink)
Lil Sulf - '94 Toyota Corolla
90 day: 47.62 mpg (US)
I reckon it be thread bumpin' time.
I have some cheap primewells, that were $40 when I bought them 2 years ago. The same tire is now $50, (?). Anyway, I want a SERIOUS upgrade, as I've have tread separation in one of my tires, and I got my prorated warranty a few weeks back for a new one.
I've been looking for some LLR tires, with good pricing, and it seems that the Ecopia EP100 is the best tire for the mpg, and has especially good wet traction. They are about $80 each for my tire size, but I'm willing to pay that kind of money for an upgrade from my low quality tires I have now. I deliver pizzas now, and I'm planning on going on a huge road trip this summer, so the savings will come much faster than I thought they would a few months back, when getting new tires would not have made financial sense.
I have a 94 Corolla, and my tire size is 175/65/R14.
Any other good LRR tires that would serve my needs?
And that's without a Scangauge o.O
Old 04-01-2010, 03:09 PM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
The original insight came with Bridgestone Potenza Re92. That specific size is, I believe, still the lowest RR tire out there. Otherwise, I'd look at the tirerack test, or talk to basjoos who runs the same size. He gets to test a fair number of tires with the miles he puts on.
Old 04-01-2010, 03:32 PM   #13 (permalink)
The Michelin energy saver a/s tires rated a little higher in the tire rack FE testing. The Ecopias were slightly better in traction as I recall, and also a fair amount cheaper. I just ordered the Ecopias for my Prius.
Old 04-01-2010, 05:45 PM   #14 (permalink)
Hypermiler
Wagons
Those ecopias are doing very well for diamondlarry. He had a 121mpg segment yesterday.
Old 04-02-2010, 02:23 AM   #15 (permalink)
Do you know what pressure he is running with the Ecopias?
Old 04-02-2010, 08:02 AM   #16 (permalink)
Likely more than you'll want to run, lol. Last time I was in his car they were 70 psi if I recall correctly. Larry is a bit... extreme.
Old 04-02-2010, 09:10 AM   #17 (permalink)
Hypermiler
Wagons
The prius tire pressure sensors light up at 70 psi and last I heard, the light was on.
I'm running 60+ myself.
Old 04-02-2010, 09:34 AM   #18 (permalink)
I comparing the Michelin Energy Saver with the Good Year Fuel Max and the General Tire Altimax.
I'm leaning towards the Michelins -- they are lower revs per mile (larger diameter) and they weigh the same (17 pounds). This seems to be the lightest for the 185 width 15" diameter tires. The Michelin tread wear rating is lower. than the Goodyear's, but similar to the General's.
The General's have higher sidewall max pressure, and better wet traction, and they cost (a lot) less.
Hmmm.
Old 04-02-2010, 09:42 AM   #19 (permalink)
I don't think the Altimax is designed to be LRR at all. Not that its a bad tire, I just know you'd get better FE with the two others.
Old 04-02-2010, 11:54 AM   #20 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
I have GY Assurance Fuel Max tires. There is also a "WeatherHandler Fuel Max" but it may be an exclusive for sears. The GY's are rated for 51 PSI; they didn't fee stable until I hit 67 PSI in 'em and had 1000 miles to wear off the 'newness' of the tire.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 05:24 PM
155/80-13 tires (looking for LRR options) Daox EcoModding Central 69 01-11-2011 12:47 AM
What are the best LRR Tires ??? hypermiler01 EcoModding Central 1 10-08-2008 08:55 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 03:49 PM
