Old 05-01-2010, 03:49 AM   #1 (permalink)
jackbauer's Avatar
Brush advancing videos
So i decided to have a go at advancing the brushes on my spare motor following on from some advice on the evtech list. I've videoed the process so far:
I want to get it right in order to help others so i'd welcome any comments just in case i'm doing it wrong! Oh and any comments on the motor would be great
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 05-03-2010, 11:55 PM   #2 (permalink)
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
Looks good!
I advanced the brushes on my motor a while back - I first started at ten degrees but found that for my particular application ten was too much. Power and acceleration were a bit off, and the motor was much less efficient. I drilled and tapped a set of holes between the zero and ten degree holes for five degrees advance. It now is a bit more efficient (240 vs 250 wh/mile), the top speed is two MPH faster, and acceleration is a bit better. FYI I have a 36v rated motor that is operated with a 48v pack.
While my setup is probably running at a much lower voltage than your car, the same principals apply.
From the diameter of your brush ring, I'd guess that you moved the brushes about 5 degrees. If you notice an improvement, you may want to see if an additional bit of advance works for your setup. If your pack voltage is significantly higher than the motor nameplate rating, more advance than five degrees may work out. If you find that the vehicle doesn't respond as well as it used to you can always move it back to five or zero.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-24-2011 11:25 PM
Motor Brush Advance TomEV Fossil Fuel Free 19 05-07-2009 11:50 PM
DC motor brush seating drag racing GO JUICE lurch Fossil Fuel Free 0 04-14-2009 11:27 PM
