Old 10-13-2018, 06:46 PM   #31 (permalink)
teoman's Avatar
A3 - '12 Audi A3
A friend did a quick demo with his vagcom. There was a torque reading there.
Torque vs rpm vs fuel in g/s would provide a good map?
Not sure how the torque is calculated or if it is measured.
Old 10-30-2018, 03:22 PM   #32 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I have some data now if anyone is interested in collaborating.
Old 05-06-2019, 12:28 PM   #33 (permalink)
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
OK, for the not so smart guy (me) in the room.
Someone suggested an indicator showing different colors representing the BSFC "islands" as a visual reference to help keep the driver in a better FE range (speed/rpm). Would an old school vacuum gauge do the same thing? Or is my confusion showing again?
If nice guys finish last, are you willing to pay the price to finish first ?
Old 05-07-2019, 12:23 PM   #34 (permalink)
teoman's Avatar
A3 - '12 Audi A3
That is one indicator.
Old 05-07-2019, 12:43 PM   #35 (permalink)
90 day: 51.16 mpg (US)
I'm not so sure such a visual would help. A driver needs to travel a particular speed, and the only variable to maintain that speed is which gear they are in. Generally, you want to be in the tallest gear that will allow you to maintain speed.
Engines produce a certain amount of power at a certain torque and RPM. In fact, horsepower is torque * RPM / 5252
The reason that the BSFC map isn't that useful is that it doesn't factor in the other variables such as increasing wind resistance due to traveling faster. It simply shows the most efficient RPM and throttle position (torque) to produce a given amount of power.
MPG or liters per 100 km is a better measure of efficiency because it factors in all of the variables.
So, BSFC is a good tool for engineers, but MPG is the right tool for drivers.
Old 05-07-2019, 01:05 PM   #36 (permalink)
teoman's Avatar
A3 - '12 Audi A3
True, but having the chart and where you are at would enable you to make the proper adjustments without trial and error.
Old 05-07-2019, 01:52 PM   #37 (permalink)
Absolutely, which falls more under the category of engineering than driving. The more extreme ecomodders here would use BSFC to inform their designs, but the casual eco drivers here would not have use for the info.
Old 05-08-2019, 06:02 AM   #38 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
An instantaneous fuel economy vs acceleration gauge would be helpful for those of us that use PulseNGlide to use the best throttle opening position during the pulse. And help us choose the best gear for slower speeds while traveling through slower city streets.
