Old 11-29-2011, 11:53 PM   #1 (permalink)
BSFC Map for Honda CR-Z
Anybody have a BSFC map for a Honda CR-Z?
Old 12-03-2011, 07:05 PM   #2 (permalink)
Short of a full map... any suggestions on throttle/rpm combinations for optimal fuel usage?
Old 12-05-2011, 08:41 AM   #3 (permalink)
I'd use the same as any other engine. ~80% load and shift at 2000-2500 rpm. If you can disable IMA assist you'll be even better off.
Old 10-06-2012, 01:41 AM   #4 (permalink)
Rondi - '12 Honda Cr-Z Ex
Why would disabling the IMA help? Often it is assisting at highway speeds.
