Old 09-14-2019, 09:37 AM   #1 (permalink)
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
Under body air flow idea ?
Hello again everyone.
Having an hour drive to work everyday on the same roads sort of puts me in "auto pilot" and I can let my mind wander through crazy ideas. This is another one. I have no clue if it has any merit at all, but I thought I would at least share it and maybe learn something new again from you all.
This came from reading the thread about tire deflectors and spats here:
https://ecomodder.com/forum/showthre...ats-17548.html
Seeing the pictures of how short vertically some of the stock deflectors/spats are on some of the cars in the pictures, while maybe not the perfect shape or height, they must have some advantage or they wouldn't be there. Some only looked to be 1 1/2" tall at most. So that got me thinking, if such a short piece of plastic can move enough air from the front of the tires, can the same concept be used in other places for some small advantage.
So this is what I came up with. If you used something like aluminum angle trim (mainly because it's cheap and easily installed) on the underside of a front under tray, could it help? Some people (me included) don't have the skill or ambition to fabricate a full length under body tray. But may try a half or just front tray that extends to just behind the front wheels. The picture probably explains where my head is at better than my words. Dotted lines = longer tray/longer deflectors.
If you extend the "deflector lines" out they would be just outside the rear tires, similar to the large deflectors you see on semi trucks. So, just how far off base am I? could this help keep some of the air away from the under body stuff like differential and rear bumper on older vehicles or pick up trucks?
ID:	26830   Click image for larger version
If nice guys finish last, are you willing to pay the price to finish first ?
The Following User Says Thank You to hat_man For This Useful Post:
aerohead (09-14-2019)
Old 09-14-2019, 12:44 PM   #2 (permalink)
spats
The 'spats' cause the air to jump the wheelhouse tire-flop void under the car (upside-down) then re-attach to the belly pan sections immediately aft.
Unless you have a streamlined structure back there,there is no surface on which the airflow can reattach to,and you just have turbulence and drag.
If you had belly-pan up to the rear axle area and a rear bumper as low as the belly,you could get the air to create a pool of dead air within that span without any spat.However,for the lowest drag,you'd want to fill this area in with at least a level panel.Subaru tested this in 1985 and it was shown to definitely lower drag.An up-swept diffuser would be the best.
Old 09-15-2019, 03:52 AM   #3 (permalink)
I thought I understood, until I read aerohead's response.
Is the front at top? What are the blue lines? They would extend to just above the lower wheels.
Are you proposing something like a Gurney flap or is the angle/channel to support an undertray?
Old 09-16-2019, 09:05 PM   #4 (permalink)
The angle trim doesn't support the undertray just attaches to it. I was thinking like the prow of a boat. Something to just help redirect a small portion of the air outwards. My thought was, if you could move some of the air out and away from the big ugly "parachute effect" area at the rear, there might be a small advantage. Nowhere near perfect, but every little bit helps, right?
With the picture being at an angle and just finishing a couple of "pork chops in a can" my fairly weak MS Paint skills are pretty much shot on this one, but maybe this helps?
The dotted lines only represent the idea if someone had an undertray that extended further back to say behind the rear wheels, but no farther. Green for the extended tray, blue for the extended angle trim. I guess if a person had a full undertray, they could put the trim all the way back to just in front of the rear wheels?
Old 09-17-2019, 12:38 AM   #5 (permalink)
Ahh! You going to make me have to draw a picture.
I'd understand better if the blue line was extended as a dotted line to the back of the dotted green area. It looks like it would hit the front axle line, not behind the rear wheels.
So I guess the proposal is an L-shape not a V-shape. I suspect it's too small to matter. Here are some examples, a Ferrari that shunts air sideways into an external duct
A race car that does what you want your idea to do.
The diverter expands the air, then it is sliced off and expelled behind the front wheels.
rob.e (03-11-2020)
