In Cab Operated Electric Telescoping Trailer Tongue
My design to draw a trailer up for highway aerodynamics, and extend it back for tight turns around town. All done without having to leave the car.
https://www.youtube.com/watch?v=UyYONaqJ8zU |
After I designed this, I found the heavy duty, probably hydraulically operated, version on You Tube. Their version uses lock pins. My version counts on the gearmotor to prevent creep back. I will have a red light in the car to tell me that the trailer is pulled up tight, and if it creeps back, the light will go off, and I will push the "Draw Up" button. But I think the gear reduction in the gearmotor will be hard to run backwards through the all thread.
Here is the commercial version: https://www.youtube.com/watch?v=KY0ugxC8RPo |
I'm bothered by the way the inner or outer surface of each square tube is a bearing surface. Teflon buttons or something?
Why couldn't you have the motor at the hitch end? Could you get the gear drive inside the 3 1/2" pipe? Cut out two sides of the pipe and box the opening? |
I AM a bit concerned about the shortened wheel base in Highway Mode. I've heard that shorter trailers are more skittish.
I was taught that it's the ratio between the TV axle/hitch and hitch/trailer axle. Moving the hitch closer to the tow vehicle axle is [proportionally] equivalent to lengthening the tongue.
slowmover can tell you about a swinging hitch that does something similar. I don't recall the brand name or how it locks (or not). |
A Jim Hensley patented hitch locks & unlocks. 120# without vehicle hitch receiver.
PULL RITE used to make a swinging constant-distance hitch. But it weighed over 400#. |
Moving the trailer axle rearward on trailer frame is an old method for better stability. But can trailer design handle it? It increases forces at other end (strain). |
(Have I got this backwards?) |
