In Cab Operated Electric Telescoping Trailer Tongue
My design to draw a trailer up for highway aerodynamics, and extend it back for tight turns around town. All done without having to leave the car.
https://www.youtube.com/watch?v=UyYONaqJ8zU |
After I designed this, I found the heavy duty, probably hydraulically operated, version on You Tube. Their version uses lock pins. My version counts on the gearmotor to prevent creep back. I will have a red light in the car to tell me that the trailer is pulled up tight, and if it creeps back, the light will go off, and I will push the "Draw Up" button. But I think the gear reduction in the gearmotor will be hard to run backwards through the all thread.
Here is the commercial version: https://www.youtube.com/watch?v=KY0ugxC8RPo |
I'm bothered by the way the inner or outer surface of each square tube is a bearing surface. Teflon buttons or something?
Why couldn't you have the motor at the hitch end? Could you get the gear drive inside the 3 1/2" pipe? Cut out two sides of the pipe and box the opening? |
I AM a bit concerned about the shortened wheel base in Highway Mode. I've heard that shorter trailers are more skittish.
I was taught that it's the ratio between the TV axle/hitch and hitch/trailer axle. Moving the hitch closer to the tow vehicle axle is [proportionally] equivalent to lengthening the tongue.
slowmover can tell you about a swinging hitch that does something similar. I don't recall the brand name or how it locks (or not). |
A Jim Hensley patented hitch locks & unlocks. 120# without vehicle hitch receiver.
PULL RITE used to make a swinging constant-distance hitch. But it weighed over 400#. |
Moving the trailer axle rearward on trailer frame is an old method for better stability. But can trailer design handle it? It increases forces at other end (strain). |
(Have I got this backwards?) |
Problems in Towing come with maintaining straight-line stability. Overly forward COG contributes.
Too Fast for Conditions can happen in seconds. I’m not qualified to say whether or not your idea will work. But I’m not comfortable when I’m passed on the road by someone with an overloaded hitch rack. When that rear axle loses traction, it’s all over. Uncontrollable. But a trailer spreads that load. Until it’s out of alignment. The shorter that distance from axles the better, to some degree. Just remember that trailers do not lend stability. As before I don’t quite think the time & effort will pay. A trailer? Great. Changing combined vehicle dynamics? Maybe not great. Low MPG a regular RV owner complaint. If a telescoping trailer tongue on a HI-LO could have worked, I think we’d have seen it. A perfect storm is where all the bad pieces come together at once. On the highway, that’s life-changing. Literally no time for correction or stopping. FE is about good predictable performance. A high, a low, and a money-in-the-bank accurate number for planning highway trips. My pickup can do 24-mpg without end (exceptions to mountainous or non-Interstate). Safe to budget number. But there’s less friction my running 62-mph than 58-mph. An easier day on the road. Easier = higher level of attention & awareness as the day goes on. A trip plan is what covers the transitions. The margins. How to preserve 10ths. As to the trailer: I’d MUCH rather have the trailer than an overloaded tow vehicle. Easier on the vehicle & driver. But trailers too small for brakes present problems of their own. As do single versus tandem axle (tridem is awesome). Best brakes on a trailer (mine is 35’) means a shorter stopping distance than the tow vehicle solo. The trailer brakes LEAD the tow vehicle in time & application force. Brake control is also what stops trailer snaking (oscillation; sway). The aero can be addressed. A telescoping tongue would not be my approach past storage. . |
Thank you.Guess I'll concentrate on forward panels, perhaps receiver or ball mount mounted. I appreciate your knowledge.
You can get closer coupling with a single wheel trailer. I invoke the name BamZipPow. http://i.imgur.com/lPaURnC.jpg https://ecomodder.com/forum/showthre...ows-31144.html |
I have built trailers and I wouldn't attempt it.
My 4x8 trailer pulled by my leaf reduces it's range by maybe 20%. That thing is so small it's going to barely do anything to the mileage. You have a prius so you don't even have to worry about running out of battery. Ideally the distance from your hitch to your axle would be about the length of that cargo capsule, then about 2/3 of the capsule would be in front of the axle. You need stability. That does not look like a stable design at all. |
I really REALLY like Knox & Aerostealth on trailers behind buses, so to speak.
I’m in favor of trailers, in general. I’ve loved BZPs work since he got started. It’s the only way to RV camp, IMO (a lifetime of experience) But it has to give more than take. |
Do you have any use besides the aerodynamics? If not a collapsible boat tail is called for. This was modeled for a VW Type II, but something similar could be adapted. https://ecomodder.com/forum/member-f...pe-ii-boat.jpg Fiberglass rods and rip-stop nylon. Follow Mair instead of Hucho. The rigid floor could have a skateboard wheel that flies above the ground. Like Dark Aero without the weight and oscillating tail wheel. Quote:
2 Attachment(s)
You guys have helped me a lot. I've abandoned the telescoping tongue, and will now modify the main body of the Harbor Freight trailer to better fit the X-Cargo 20 Cu. Ft. carrier, I will splice in a couple of 24 inch pieces of angle iron to add 19 inches to the main frame. Relocating the axle to possibly gain a longer WB for stability.I will possibly use some gap filling sliders ahead of the carrier to smooth the airflow. The first picture is the stock frame illustrating the hangover that I dislike, and the second picture is the frame stretched 19 inches.
So there will be an electric screw jack at 'A'?
How many inches wide is the carrier? |
For rebuild version 1 of my 4x8 trailer I had the wheels pretty far back. Nearly 6 feet back on an 8 foot trailer deck. It rode great. The idea was I would tow it with my suburban so if there was 500 lb of tongue weight, no problem. Just load it fast and slopy, no problem. Then for version 2, it was being mostly car towed so I put the axle between 1/2 and 2/3 the way under the length of the deck to better control tongue weight. Now if I don't load it correctly I get trailer sway really bad. With that setup I would be surprised if you saw a 10% fuel economy hit. |
36x67" on a 40" frame. The square frame under the rounded carrier is suboptimal. The carrier is probably thermoplastic and can't be widened. While you're lengthening the deck you could narrow it to 32".
Else just put a skirt on it. |
1 Attachment(s)
What's the inside dimension of the floor in the carrier?
Unless you have the Harbor Freight trailer already I'd look for a T-frame https://www.tyronesnelltrailers.co.u...frame3-500.jpg https://www.tyronesnelltrailers.co.u...road-trailers/ The overhanging HF trailer would be what I believe they call, in the UK, a 'dogs breakfast'. Check out this: https://ecomodder.com/forum/member-f...untitled-4.jpg There's not much difference from 0.558 to 0.611. If it's smaller than the tow vehicle, it might offer something for some part of the wake to reattach to. |
1 Attachment(s)
It's lower than the tow vehicle, and I plan some gap filler
2 Attachment(s)
It's lowr than the tow vehicle, The Harbor Freight frame will be stretched 19 ", and I plan some gap filler
I spent too much time trying to find one of Bucky's more obscure inventions, the Mechanical Wing. I eventually found it's name in a book so this turned up:
http://3.bp.blogspot.com/-aYf43U1X5_...nical-wind.jpg http://3.bp.blogspot.com/-aYf43U1X5_...nical-wind.jpg Note the 2nd hitch to locate the deployable box. But I did find this. https://ecomodder.com/forum/member-f...8372-blue2.jpg |
Paint & matching wheels (alum covers) is an excellent idea. That’ll get you the thumbs up. Admiration.
eBay Other |
1 Attachment(s)
NEW, SAFER IDEA FOR VARIABLE LENGTH BALL MOUNT.
When you're backing a trailer the length ratio of tow vehicle rear axle/trailer axle affects control-ability. This goes the wrong way for that.
1 Attachment(s)
I know it sounds shortsighted, but I plan to park in a way that I don't have to back. I really like my earlier idea, the one someone didn't like because they thought a load bearing tube shouldn't be sliding in and out of another tube. That one would keep the coupler and ball in the same location and shorten or lengthen the tongue for aerodynamics or maneuverability.
I have a failed VW Type III jack. Unlike the Beetle jack it uses a worm gear and under load the worm came adrift at one end. My camera has failed or I'd take a picture.
Your current [previous] design is possibly the best so far. |
Well, my "NEW SAFER IDEA" has the problem of moving the ball back, and amplifying any up/down left/right movement of the car, Though this would be in town, extended, at lower speeds. My older, telescoping tubes under the trailer keeps the ball in the same place, near the bumper, but by drawing the tongue under the trailer on "suck up" moves the C/L of the trailer back, lightening the weight on the ball. They both change the weight felt on the receiver, but the "NEW SAFER" design adds unwanted sensitivity when extended.
Maybe I need a bit of both. |
I guess you'll find out when you try.
