Old 10-05-2011, 02:59 PM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Mailbag: is there a fuel economy gauge for a 2003 Freightliner semi?
Got this question via e-mail:
I am looking for a fuel economy gauge for a semi truck. Do you have any thing that will or can work for me, we have a 2003 freightliner with a detroit diesel in it ? Thanks
Anyone know of anything?
Old 10-05-2011, 05:00 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
A Google search shows they seem to have OBD2, so I'd expect an OBD2 tool to work.
One of those links :
Freightliner OBDII Readers OBD2 Code Tool Scanner
Old 10-05-2011, 07:24 PM   #3 (permalink)
...beats walking...
...one of the Kiwi MPG ads mentions "...works with diesels..."
Old 10-06-2011, 08:26 PM   #4 (permalink)
90 day: 19.36 mpg (US)
Detroit Diesel makes a driver readout. Expensive, though. Look up ProDriver on DDEC II engines.
Old 10-16-2011, 03:52 AM   #5 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
If the truck has OBD-II, then I think a Scangauge II would work. I used to have an '06 Jetta Diesel, and the Scangauge worked fine. I don't see why the Scangauge would be incompatible with other diesels.
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
DeepScale
Old 10-21-2011, 11:31 AM   #6 (permalink)
Hydroline3 - '09 Mitsubishi L200 Business, Double cab
90 day: 40.86 mpg (US)
For professional use with big rigs that burn tons of diesel, it may make sense to invest in more expensive systems. One such system is Blueflow. Blueflow Technologies AB
It uses advanced flow meters from AIC combined with GPS and provides output from a PC or a phone. There are also possibilities for web based statistics but this is targeted to fleet management and cost a bit extra I think.
Old 11-12-2011, 08:02 PM   #7 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
As Freightliner tech, I've never seen an OBDII port on a 2003( or 04, or 05,...). Freightliner is GOING to be incorporating OBDII into their on board systems in the near future. Some rigs did come with mileage computers in the dash, most do now( can't say all as I haven't worked on everything). Depending on your dash, you might be able to upgrade.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
