Old 09-23-2017, 08:28 AM   #1 (permalink)
How much power does it take to drive an oil pump
That is what I would like to find out.
I need to prime the oil system on my new engine. So I will connect a power meter to my drill and turn it.
See if I can get my optical tachometer working to see how fast it's turning.
For the oil I am just going to dump in a quart or 2 of 0w-20 weight oil. Just enough to cover the pickup once the oil system is primed, oil filters and oil cooler are filled.
Old 09-23-2017, 09:51 AM   #2 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Power to a positive displacement pump is Hp = GPM X PSI / 1714. That's the theoretical power at 100% efficiency. Divide by efficiency to get actual shaft horsepower.
If you measure flow rate at some RPM, and find the drive ratio of the pump (pump RPM vs engine RPM), then you can calculate oil pump horsepower as a function of engine RPM and oil pressure. That would be interesting information.
Old 09-23-2017, 10:18 AM   #3 (permalink)
That's ideal. As we find most things on a vehicle are far from ideal.
This will be real world.
Problem is no one really seems to know the efficiency of an oil pump and actual gpm is no more than wishful thinking compared to published.
Old 09-23-2017, 02:00 PM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
My Volt has a variable oil pump to save gas, so it must be somewhat energy intensive to pump oil.
But boy does the Volt make the oil black,
I'm starting to monitor gas miles manually so I can change off my own timing instead of the oil DIC .
Old 09-23-2017, 09:41 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
So does my Renault diesel. Renault claim it's worth 0.5% in mpg gain, IRC.
Old 09-23-2017, 09:41 PM   #6 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
I know that back in the 70s we had a small block Chevy come apart at the track. The driver said that when the oil light came on the car gained about 50 hp. This was his guess, we ran Kendall 50 wt racing oil and turned the engine 8300 rpm. He shut it off but the engine was already junk.
If you want to check actual load you will need to use a distributor housing so the complete oil system gets pressure. I assume you are working on a Chevy. The distributor housing completes the oil passages to the lifters. We always primed our new engines back when they had distributor driven oil pumps.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 09-25-2017, 12:02 AM   #7 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
I was just wondering if you could create a pumping system that utilizes springs and a small part of the combustion chamber pressure to move the oil through the motor??
Old 09-25-2017, 01:18 AM   #8 (permalink)
teoman's Avatar
A3 - '12 Audi A3
You mean something like hooking it up to the turbo?
Old 09-27-2017, 10:13 PM   #9 (permalink)
No, I mean like have a 1" cylinder next to the combustion chamber that has some gas from the combustion leak into it at its highest pressure will having a spring to return the piston to the top. Like a piston type accumulator tank with a spring on the oil side for return to the top of its stroke!!
Old 09-28-2017, 02:49 AM   #10 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Take the part I have marked in red, out, and is that not exactly what a standard oil pump does? Only it utilises the pressure in the cylinder instead of wastefully leaking it out. You cannot get something for nothing. If any part of the engine pumps the oil then you must use energy (fuel) to drive it. The only way to lubricate the engine for free is to use solar power(!) or the waste heat from the engine.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
