Old 04-09-2022, 06:53 AM   #1 (permalink)
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
Engine off hypermiling & tailpipe emissions
While lurking, I came across a couple of ~10 year old threads expressing concern that certain engine-off hypermiling techniques might actually increase emissions:
https://ecomodder.com/forum/showthre...ute-14571.html
https://ecomodder.com/forum/showthre...ing-20338.html
With engine start-stop technology becoming commonplace, I was pretty sure someone must have done a scientific study by now so I did a little digging and came across two.
This one measured Cold, Hot, and Warm start emissions of vehicles of various ages (and emissions standards). While engine off was generally better, it did find that certain emissions were lower when idling for a full 5 minutes rather than shutting off & restarting. Counter intuitively, newer cars were more prone to this:
https://www.weber.edu/wsuimages/ncas...nal_Report.pdf
On modern engines, carbon monoxide emissions are higher stopping the engine & restarting rather than idling for 5 minutes:
On modern engines, NOx emissions are higher stopping & starting compared to idling 5 minutes:
Stopping the engine for 5+ minutes results in fewer hydrocarbon emissions than idling for all engines:
CO emissions:
NOx emissions:
HC emissions:
As a reminder of the emission tiers:
Tier____Age
Pre-0 __1980 and older
0 _____1981-1993
1 _____1994-2000
NLEV __2001-2003
2 _____2004-2016
This study of a modern euro-4 standard scooter in real-world city traffic found that actual emissions of CO and HC were greater by 57% and 4%, respectively for the scooter with the start-stop system enabled, while the emission of NOx decreased by 10%. The application of the start-stop system contributed to the reduction of the fuel consumption/CO2 emission by approx. 12%.
https://www.sciencedirect.com/scienc...61920920308683
As many others noted in the prior threads, these are just tailpipe emissions. At this point, the total emissions from extracting, refining, and transporting the oil are much higher than those from tailpipe so it is probably "less bad" to maximize mpg rather than burning more fuel to minimize parts-per-million tailpipe emissions. And even though tier 2 engines showed higher CO & NOx emissions when stopping & restarting, those emissions were still lower than idling older engines.
Name:	Screenshot 2022-04-09 03.14.17.jpg
ID:	31885   Click image for larger version
Name:	Screenshot 2022-04-09 03.12.55.jpg
ID:	31886   Click image for larger version
Name:	Screenshot 2022-04-09 03.10.46.jpg
ID:	31887   Click image for larger version
Name:	Screenshot 2022-04-09 03.07.34.png
ID:	31888   Click image for larger version
Name:	Screenshot 2022-04-09 03.04.43.png
Name:	Screenshot 2022-04-09 03.03.05.png
The Following 4 Users Say Thank You to Drifter For This Useful Post:
Gasoline Fumes (04-10-2022), MeteorGray (04-12-2022), Piwoslaw (08-23-2022), some_other_dave (04-12-2022)
Old 08-23-2022, 02:52 PM   #2 (permalink)
There are cars with V engine layouts (2 cylinder banks, 2 cats) that don't actually shut off the valves when deactivating a bank of cylinders, thus cooling down the cats. They alternate banks to keep both cats warm enough. It seems like as long as the cats are above light off temperature emissions are negligible.
