Old 06-03-2009, 12:13 PM   #1 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Car with a Carb
What's the best way in instrument & log a vehicle with a carb for fuel economy?
A vaccum guage & fill up at the same pump all the time?
Thanks
Don
Old 06-03-2009, 02:57 PM   #2 (permalink)
The Commuter - '96 Toyota Corolla DX
90 day: 39.6 mpg (US)
It's a good start. You can buy an O2 sensor and a gauge and mount it in any vehicle. It takes a bit of work to install it if you don't have a bung already welded in your exhaust, but it will show your air/fuel ratio in real-time. Just make sure the gauge and the sensor operate on the same voltage system (0v is rich, 1v is lean, etc.) like you would do with a fuel gauge.
Old 06-04-2009, 10:12 AM   #3 (permalink)
Thank you
It has an oxygen sensor already as the carb is "computer controlled". Hopefully I will soon be rebuilding a much better non-electric carb & the O2 bung will be freed up.
Don
Old 06-04-2009, 12:11 PM   #4 (permalink)
That would be best, otherwise see if you can splice into the current O2 sensor wire and connect a gauge to it.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Electric Car Wind Generator Charger demo unit bennelson Fossil Fuel Free 12 04-28-2009 11:20 AM
Aero suggestions for my car atomicradish Aerodynamics 17 07-27-2008 02:29 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
