Originally Posted by xntrx
The egr is vacuum controlled, so a vacuum leak will affect that and the map sensor's load reading. I'd start there and check the ignition timing (unlikely, but never hurts).
I bought the car with it retarded 6 degrees (timing was retarded to pass smog I think, oxygen sensor was slow before I replaced it so it would flip flop between high NOx and high HC on the smog test,) when I got my hands on an inductive timing gun I advanced it by 9 degrees for a 3 degree advance.
Originally Posted by Baltothewolf
I know perfect solution, don't drive 72mph  .
72 MPH is to simulate heavy loads like seen in P&G. I'm not going to watch my multimeter while accelerating, doing it like this gives me more time to determine where the engine switches over to a burnt in A:F map so that I can keep the car at the very limit of running closed loop.
Originally Posted by bestclimb
does it hit at the same RPM in other gears?
No. 72MPH is 3600 RPM or so, it stays closed loop until at least 4000 RPM in other gears when under lighter load.
I need my data cable, but I lost my high wattage soldering iron.
