Old 01-14-2009, 10:21 AM   #1 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 VW Golf wagon
90 day: 40.36 mpg (US)
Low-speed "cruise control" using idle speed controller?
When I'm cruising at a constant, low speed of 30-40 km/h (18-24 mph) I'm usually in 5th gear, which results in a lower RPM than the engine's idle speed controller would like (for a moving car), so the engine automatically increases the throttle and the car cruises by itself at about the desired speed with my foot off the gas. That's about 1000 RPM (the engine tolerates down to about 600 RPM without balking).
What's more efficient: the above "cruise control" method or should I be in 4th, so that I have to add a little throttle myself? What have you ScanGaugers and MPGuinos found? And will the engine's idle speed throttle motor wear out faster?
Thanks!
You ever notice that birds pulse & glide, too?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 12:41 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
