Old 12-08-2015, 02:44 PM   #1 (permalink)
...beats walking...
"Old" GPM (1/MPG) equation
Don't know how relevant it might be to *current* vehicles, but back in 1961-1967 a Ford Motor Company engineer came up with this logarithmic-form equation for estimating fuel consumption (161 car-sample):
c = K*(wt^0.3067)*(cid^0.3469)*(ar^0.3395); R^2 = 0.932
where:
c = gallons-per-mile
K = 5.248 x 10^-4
wt = weight in lbs.
cid = cubic-inch displacement
ar = axle ratio
• source: SAE Automotive Fuel Economy, Vol. 15 (PT-15), 1976, "Factors Affecting Vehicle Fuel Economy," by Clayton LaPointe, Ford Motor Company, page 105.
The Following User Says Thank You to gone-ot For This Useful Post:
aerohead (12-08-2015)
Old 12-08-2015, 03:27 PM   #2 (permalink)
Related to Louis LaPointe?
Old 12-08-2015, 05:03 PM   #3 (permalink)
darcane's Avatar
where:
K = 5.248 x 10^-4
wt = weight in lbs.
ar = axle ratio
Looks like a typical empirical equation. It should be close if you were to build a gas powered car with 60's technology... Changes in technology will alter the constants in the equation.
It comes out to 26mpg for my Civic, which is likely close if it were carbureted, had 60's aero, and were on crappy old tires.
You could probably generate a new version of one that would be more accurate. Or, likely a few of them to deal with different engine cycles (gas, diesel, hybrid) and aspiration (NA/turbo).
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 12-08-2015, 05:26 PM   #4 (permalink)
equation
It's cool that in it's day,they'd have a numerical algorithm which could,within an acceptable margin of error,predict performance with such few 'hard points' of data.
My college text for internal combustion engines and air pollution had a road load estimator equation which presumed a constant Cd and rolling force coefficient for tires for all cars.It only asked for weight,frontal area,and velocity.
Old 12-09-2015, 01:33 PM   #5 (permalink)
...beats walking...
The "hidden agenda" reasons I had for posting this "old" equation:
1) Shows how only WT, CID and AR are needed to estimate Fuel Economy (it's basically all about engine displacement and rpms).
2) Shows type (logarithmic) equation (product-of-powers): c = K*a*b*c
3) Shows quasi-cubic-root "power" for each variable: ie: WT^(≈1/3), CID^(≈1/3), AR^(≈1/3).
4) To provide *another* way to visualize/quantify how FE can be quantified...ie: "put into numbers"
...or, "rule-of-thumb" roughly: mpg ≈ 1900/(WT*CID*AR)^(1/3)
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
aerohead (12-09-2015), Joggernot (12-09-2015)
