Old 02-28-2010, 10:28 PM   #11 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
daverbmxer,
i opened a thread with the same question. -- i already had my VAC gauge installed.
i did find conditions, like a highway on-ramp, where the lower gear yielded better vacuum.
i have an automatic transmission, so lugging is pretty unlikely to happen, but i come close.
the only reasonable response i received was old tele man's response.
my vehicle is too old for a scanguage to compare these gears, but i think he made great sense.
single person car thread
Old 03-01-2010, 06:40 AM   #12 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Luvit - You could install a marine fuel meter, such as a flowscan, to determine GPH usage of the engine.
Old 03-01-2010, 07:19 PM   #13 (permalink)
epic stock master
luvit's Avatar
what do i do with that GPH figure? ..kinda see GPH in either gear?
Old 03-01-2010, 07:35 PM   #14 (permalink)
One Cold North Dakotan
Sammy - '88 Suzuki Samurai JX
90 day: 21.41 mpg (US)
Doc - '91 Suzuki DR350S S
90 day: 48.14 mpg (US)
Those can't be cheap..
Old 03-01-2010, 08:26 PM   #15 (permalink)
If you know GPH and MPH, you can compute MPG. They aren't overly cheap, about $150 for an analog gauge type, more for digital display. For a carb, however ,there isn't much other choice.
Old 03-01-2010, 08:52 PM   #16 (permalink)
Duff-stiva - '93 Ford Festiva Trio
90 day: 42.81 mpg (US)
Originally Posted by bestclimb View Post
When cruising in 4th or 5th gear even with identical throttle positions you are sucking more air through at higher rpm which mean more fuel as well.
Here is the answer
Old 03-03-2010, 12:34 AM   #17 (permalink)
A tall velocity stack on the carb perhaps?
Old 03-03-2010, 01:01 AM   #18 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
When I first got my Scangauge, that was the first test I did - a 4th, 5th, and 6th gear mpg comparison drive at the same 35 mph speed on a slight uphill climb about a mile long. The mpg results showed 5th gear beat 4th, and 6th gear beat 5th. This was in my SE-R.
Here's another. I've run the same 10 mile loop in all three of my family's cars in top gear and the next gear down. That's 35 mph in top gear v. 30 mph in the next lower gear. The route is essentially level, driving at sea level with at most about a 50' elevation gain in a couple of places. Each car showed better mpg in top gear.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 03-03-2010, 08:35 AM   #19 (permalink)
...beats walking...
...the ecomodder jingle, repeat after me:
"the slowest RPM in the highest GEAR that doesn't 'lug' the engine."
Old 03-03-2010, 03:07 PM   #20 (permalink)
Old Tele man is right. That's why low end torque is good. It allows you to run in a higher gear in a lot of situations.
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Tires question RandomFact314 EcoModding Central 18 04-20-2009 11:30 AM
Prius Question Matt Herring EcoModding Central 13 07-24-2008 03:07 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
