Old 10-02-2012, 01:12 PM   #71 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by changzuki View Post
Ryan, Believe it or not I though that scenario awhile ago. Aside from physical space issues, the Subaru 360 would likely run into issues with the diesel vibration unless you were to fabricate a different engine mounting subframe of sorts... I ended up with a Honda Z600 thinking I'd diesel-ize that too but decided against it mostly for the same reasons. If you really decided to heave-ho the gas engine and went with Lithium, your 360 could really be hotttt! At least I could see it...
~CrazyJerry
Not sure if vibration would be a huge deal, a couple isolators in key spots might do the trick since it floats pretty good, probably a few alternate seat mount isolators and better gaskets would cover up the rest.
