Old 09-09-2013, 01:14 AM   #11 (permalink)
The analysis would be done on your computer. If you could send me a screenshot of the Configure/Third-Party page at info@hibouscientificsoftware.com.au I could check that the third party are fine.
After you start the plugin in SketchUp, use right-click in the window to get a menu.
Have you look at the YouTube videos? http://www.youtube.com/user/HibouSoftware - It is probably a good source of information.
There is also a written step-by-step tutorial on how to setup a case [it assumes that the installation works] at https://dl.dropboxusercontent.com/u/...ody%28A%29.pdf
Otherwise, I would be happy to send you a skp to test your installation.
The Following User Says Thank You to julien.decharentenay For This Useful Post:
NeilBlanchard (09-09-2013)
