Old 08-19-2008, 10:04 AM   #1 (permalink)
Another civic - '06 Honda Civic LX
90 day: 40.81 mpg (US)
Does resetting the ECU improve mpg?
After I had installed lightweight aftermarket rims and new tires I noticed a significant drop in mpg and did as much research as I could to fix this. I slowly raised my air pressure to 50psi and kept using the hypermiling tips I had learned to at least get my mpg back to where it was before. I couldn't wait any longer for my tires to break in so I searched the internet and found out about resetting the ECU here.
Most performance modders will reset the ecu when they install new equipment so the computer can relearn the drivers habits and get use to the new mods in the car. I wasn't sure if my slightly bigger (went from 16" to 17") rims yet lighter would be a candidate for this, but I tried it anyway. Didn't seem like there was much to lose.
Looks like it worked! I notice a change in the gear shift a bit earlier and keeping the rpms a bit lower. I checked my scangauge to make sure the settings didn't change and I seem to have gained the 3-5mpg I lost when I changed the tires and rims. I'm still not sure if it really did the trick, I guess I won't know until the end of this fillup.
I hope it only gets better when my tires break in! Has anyone else tried resetting their ecu after doing warm air intakes or anything else?
Old 08-19-2008, 11:27 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Sometimes new cars can be too smart for their own good,
Old 08-19-2008, 01:15 PM   #3 (permalink)
I guess everything needs a good reboot these days.
Old 08-19-2008, 02:25 PM   #4 (permalink)
Generally rolling resistance goes down as the tread wears, at least on truck tires.
Also a larger diameter rim, while lighter in mass, may have more inertia (not a factor for steady state cruise, but more energy to accelerate).
Old 08-19-2008, 02:48 PM   #5 (permalink)
But in a steady cruise, the bigger wheel will use less power to travel further, right?
Old 08-19-2008, 06:31 PM   #6 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Hey got any picks of the new rims installed?
Old 08-19-2008, 08:41 PM   #7 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I seem to have gotten good results from resetting my ECU after modding my intake (cold to warm), so at the very least, you aren't crazy.
Old 08-20-2008, 09:57 AM   #8 (permalink)
Tupper - '97 Saturn SW2
90 day: 37.52 mpg (US)
I can't imagine any "setting" or variable in the ECU that would care about tire size or a change of tire size. Did your overall diameter change? This could show worse mileage due to odometer/speedo error.
Old 08-20-2008, 10:03 AM   #9 (permalink)
EcoVibe - '07 Pontiac Vibe base
90 day: 38.14 mpg (US)
If you went with a lower profile tire and kept the diameter the same it shouldn't have affected it. If bigger overall, you will drop a little in FE.
Old 08-20-2008, 04:03 PM   #10 (permalink)
bigger diameter and lower profile tires. But the tires are a bit wider than the previous ones.
Konig Daylite - Black Wheels - Wheel Size & Price Details - 1010tires.com
with bridgestone fuzions 215/50ZR17.
Good in-town mpg a challenge rschoolf Hypermiling / EcoDriver's Ed 11 07-14-2011 03:10 AM
Suggestions on how I can improve my MPG on my commute?? regor Hypermiling / EcoDriver's Ed 4 06-09-2008 02:03 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
Honda Accord 96 LX Sedan Improve MPG. rjuki Off-Topic Tech 6 04-25-2008 03:14 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
