Old 04-13-2022, 01:07 PM   #1 (permalink)
6th Gen Coupe - '02 Honda Accord EX 4 cyl
90 day: 28.01 mpg (US)
Zombie Accord - '98 Honda Accord EX
90 day: 24.71 mpg (US)
Ol' Red - '96 Ford F-150 XL
90 day: 14.43 mpg (US)
Need help with
Hey guys, I'm trying to get a Ford festiva econo box back on the road for fuel savings. The vehicle presented a crank but no start condition. It would run if directly fed gas through the carburetor, so I replaced the fuel pump. The vehicle started up and ran, but after a short distance, it shut off and would never restart again.
I decided to take the carb off and clean it. There was some built up varnish. I reassembled the vehicle but it still would not start. I decided to check for spark, which led me to replacing the distributor. The vehicle will now start up with no issue, but it will only idle for 5-10 seconds before the engine shuts off. If I press the gas pedal, the engine immediately shuts off. I'm feeding the engine with gas directly from a jug, bypassing the fuel tank and filter.
Old 04-13-2022, 01:38 PM   #2 (permalink)
The requirements are fuel spark and air.
Does the distributor have a condenser or not? IIRC a bad condenser will allow idle but not revs.
Can you feed the jug into the filter?
