EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Chevy Volt driven by ABG (and good video on Jay Leno's Garage) (https://ecomodder.com/forum/showthread.php/chevy-volt-driven-abg-good-video-jay-lenos-11232.html)
NeilBlanchard 11-30-2009 01:21 PM
Hi,
The good folks over at AutoBlogGreen have driven a pre-production Volt, and they are the first journalists to drive it with the ICE running:
Quick Spin: 2011 Chevrolet Volt charges toward production — Autoblog Green
cfg83 11-30-2009 03:13 PM
NeilBlanchard -
Neato. I like the air dam detail. It looks verrrrrry familiar :
http://ecomodder.com/forum/member-cf...lt-air-dam.jpg
It looks like it's in 3 parts. I wonder if it is spring loaded so it can collapse when you hit a curb.
CarloSW2
cfg83 11-30-2009 03:43 PM
Hello -
This is an interesting blurb :
When we first talked to GM about the Volt three years ago, the thought was that the engine would simply run at a constant speed to maintain the battery charge. As development has continued, that strategy has evolved. The output of the engine/generator is based on the needs of the battery and motor, not what the driver is demanding. As the level of the battery changes, the generator is controlled to provide the necessary, electrical output. The engine speed in turn is selected to maximize the load on the engine. An engine runs most efficiently at full load. If the electrical demand is low, a lower engine speed is used in conjunction with the generator control to get the desired load.
I was expecting a single-RPM engine.
CarloSW2
tasdrouille 11-30-2009 04:41 PM
Originally Posted by cfg83 (Post 142792)
NeilBlanchard -
Our cars are starting to look normal again!
Now that this stuff is going mainstream, maybe my wife will let me put the airdam back on the Elantra...
http://www.ecomodder.com/forum/attac...1&d=1206395604
Originally Posted by cfg83 (Post 142802)
Hello -
CarloSW2
Well, it's a good news it's not fixed rpm. It allows to pick up the most efficient operating point for every load level.
cfg83 11-30-2009 06:56 PM
Hello -
Accidently found this image :
http://images.thetruthaboutcars.com/...urb-weight.jpg
This means the Volt is designed to ride about 2" lower than the Cruze.
CarloSW2
cfg83 11-30-2009 07:04 PM
Yes, you're right. It's just that I've been hoping that the "ideal" would be viable in the real world, aka an engine designed to run at a single RPM. They also ditched the 1.0 V3 Turbo in favor of the 1.4 V4.
[EDIT: V3 and V4 are the wrong term, I meant to say I3 and I4]
CarloSW2
NeilBlanchard 12-01-2009 09:27 AM
Popular Mechanics has now also driven the Volt, and they have a video that explains the reason for the change in the charging scheme: they want you to return home with an "empty" battery so you will charge it there, where it is the most efficient.
GM 2011 Chevy Volt Test Drive - 2011 Chevrolet Volt Pre-Production Test Drive - Popular Mechanics
jamesqf 12-01-2009 11:27 AM
I don't think that has anything to do with ride height. It's just that the center of gravity is lower, presumably because of the batteries mounted low in the frame.
MetroMPG 12-01-2009 01:04 PM
More reviews:
http://network.nationalpost.com/np/b.../1201Volt2.jpg
The National Post (Canada) has a review:
Exclusive Preview: 2011 Chevrolet Volt - Posted Driving
So does the LA Times:
Chevrolet Volt: A sneak peek at GM's plug-in hybrid -- latimes.com
I've moved this over to the "Hybrids" subforum. As much as GM is fighting tooth and nail to convince people (journalists) to not call the car a hybrid, it certainly doesn't fit in our Fossil Fuel Free section! Series hybrid EV is probably as close as it gets.
Apparently we can expect to see a video on Jay Leno's Garage too.
MetroMPG 12-01-2009 01:17 PM
Coincidentally, the ride height is also about 2 inches lower than the Cruze.
Not disagreeing about the effect of the pack on C.G.
http://ecomodder.com/forum/member-cf...volt-cruze.jpg
Of course these are both pre-production vehicles; no saying if their ride heights are definitely what consumers are going to see.
