Old 12-28-2009, 10:59 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
Chin Splitter?
Does a chin splitter (something along the lines of this:
Help for MPGs or downforce? I can't remember which... or is it both?
I'm thinking if it will help with MPG, then when I make my belly pan, I'll extend it out the front.
Old 12-28-2009, 11:01 PM   #2 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Improves downforce 4 sure.
I don't know about MPG.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 12-28-2009, 11:04 PM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
It improves downforce through the wing effect. It can aid MPG by lowering your stagnation point, if you mount it correctly. It might not be a noticeable gain, though, certainly not worth buying one premade.
Old 12-28-2009, 11:22 PM   #4 (permalink)
They reduce lift by preventing air from going underneath. That also reduces drag. The two aren't mutually exclusive.
Old 12-28-2009, 11:26 PM   #5 (permalink)
Mount it at the wrong angle, then get back to me about how it doesn't induce drag, rather than reduce it.
Old 12-28-2009, 11:42 PM   #6 (permalink)
Usually they're horizontal though
Old 12-29-2009, 12:03 AM   #7 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
That would be a chin "spoiler"
Here's a more dramatic chin splitter... which more than likely does no more than a smaller one. (also called a front diffuser)
Old 12-29-2009, 12:12 AM   #8 (permalink)
The splitter is horizontal. That Mustang has an air dam. The dam reduces drag and lift by the same method though, preventing air from going under the car. The difference is that the splitter doesn't block airflow coming from the front, only airflow being redirected downward by the nose of the car.
Old 12-29-2009, 12:21 AM   #9 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Ohhhhhhhh my bad. I was thinking you said vertical.
Old 12-31-2009, 01:17 PM   #10 (permalink)
splitter
My opinion,is that the splitter's place is on the racetrack,not on the street.
Neither the Corvette pictured,nor the racecar could navigate a driveway ramp without leaving their nose on the ground.
The Corvette,which can be purchased in Germany,can legally operate on portions of the Autobahn at top speed,which for some models now is in 200-mph territory.
Stability and traction are paramount to safety at these speeds,which the splitter can help with.
For normal day to day driving they would offer only a headache and hazard to surrounding traffic as you slowed to a crawl and attempted to negotiate ramps obliquely to avoid a ground-strike.
I've been there,done that,don't go there!
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 20 03-18-2014 05:31 PM
Airdam / Undertray / Splitter Construction Ideas TimRogers Aerodynamics 12 03-16-2009 10:14 PM
Airdam or Splitter? Nigel Aerodynamics 2 02-06-2009 11:39 AM
Upper front splitter apgrok1 Aerodynamics 3 05-16-2008 03:38 PM
New: Ford mods their Super Duty pickups ... chin spoiler + final drive changes MetroMPG EcoModding Central 1 01-08-2008 01:32 PM
