Old 05-22-2013, 04:42 AM   #1 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
MPGuino stopped suddenly working..
Hello!
I installed e85 fuel-box. The MPGuino did work before that, and during that.
I removed it, and then MPGuino does not display any info from injector.
I have several MPGuinos and all tested, so it can't be that.
At idle, the injector gives around 70Hz signal(Measured with Hz meter, i dont have oscilloscope).
I tried by adding some kind of lowpass-filter just to test what happens, 4k7 and 100n, and it brought some kind of signal to MPGuino, but it's very distracted.
Any thoughts what could be?
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 05-22-2013, 05:25 PM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I think that it's a disconnection somewhere between injector and guino, or maybe there's no proper ground connection to it.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 05-23-2013, 02:58 AM   #3 (permalink)
Yea that popped in my mind too when i was reading your other post,
Strange indeed... I presume the issue was based on some bad contact and it could disappear with different humidity, road bumps etc. Or it can be just noise from high voltage wires and that could disappear in dryer air, or again some road bumps.
I gotta check the injector wiring if there is something wrong. Was going to yesterday, but the weather was terrible. Today it is going to be sunshine
EDIT: I checked the wiring from the injector, but no luck.
Brrrmm
Old 07-23-2013, 04:23 PM   #4 (permalink)
Now finally i managed to get it working!
The issue was umm.. well i dont know what the issue was, but i got it working again by moving the signal wire from next to injector to next to ECU.
Why i did'nt think that before? Well because it did work before too with the same setup...
Brrrmm
Old 07-24-2013, 03:00 AM   #5 (permalink)
AndrzejM's Avatar
I think there was just a bad contact... When you hooked the cable to new point of the injector's harness it started to work again.
Old 07-24-2013, 03:13 AM   #6 (permalink)
No it was'nt that. I soldered it to the wire previously, and after new try, i moved it to another point, into the connector going to the injector. And after another try, i hooked it to the point where it first time did work. And this time, just near the ECU.
So i'm sure it was not a bad contact.
Brrrmm
Old 07-24-2013, 09:16 AM   #7 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I was on a road trip back to Canada from California, and about halfway back my mpguino suddenly stopped working as well.
Then about the time I hit the border it suddenly started working again.
My guess.. maybe it over heated?
My GPS did a similar thing in the hot California heat on my next trip down.
2000 Insight MT 106K Citrus A/C
Old 07-24-2013, 10:22 AM   #8 (permalink)
My issue was not on MPGuino itself, it was the car. I think the wiring harnesses are worn here and there and something just created a disturbance to the signal.
Maybe we should start an FAQ thread here concerning these kind of things. If someone could sticky it also.
Brrrmm
