Old 05-06-2009, 08:03 PM   #1 (permalink)
Lord Vader - '03 Saturn LW200 Sport
90 day: 33.64 mpg (US)
Casper - '88 Subaru Leone RX turbo
90 day: 26.95 mpg (US)
not sure if I introduced myself
I'm Phil My car is a 2003 Saturn LW200 I am on the verge of crossing from the basic mods to extreme mods.
Below is my car... these are the aero mods As you can see I have the upper and lower grills 90% blocked.
I also have a front tray and rear diffuser
I have wheel dams in front of the front and rear tires
I have swapped the 16 inch wheels for 15 inch wrapped in LRR rubber
I also have vortex generators along the back of the roof placed 6 inches from the back.
Power train mods are as follows:
I have a 2.25 inch engine back exhaust with a cobalt SS manifold (from my days autocrossing the car) a HAI and that is it
I do have a Scangague that is set to display... instant milage, tank milage, IAT, and Load%.
I am thinking about adding wheelskirts and a kamback as well as reducing the mirror size.
I will definitely be installing gap fillers on the body panels since plastic cars have canyons between panels.
any ideas on what to do next will be gladly considered
Phil
Old 05-06-2009, 08:11 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Your lack of boattail disturbs me.
Welcome to ecomodder!
Old 05-06-2009, 08:13 PM   #3 (permalink)
not quite ready to build a Basjoos style boat tail just yet but I might create a virtual one using air control.
Phil
Old 05-06-2009, 09:09 PM   #4 (permalink)
Looks good Phil! Welcome to the site.
Old 05-08-2009, 03:21 AM   #5 (permalink)
I think I'll be doing some gap filling tomorrow I keep looking at the car and saying to myself "Man those gaps are big"
Phil
Old 05-08-2009, 04:25 PM   #6 (permalink)
went to the local home store and bought some foam and got to filling gaps
the light grey you see is the foam and yes the gaps were that big.
I ran a 100mile test loop to see what if any difference these made and road noise is reduced significantly. I set my trip report on my scan gauge outbound 37.1mpg inbound 36.9mpg for an average of 37mpg. this was on a 55mph road with many hills I am not sure if these improved milage at all but the quiet is nice
Phil
Old 05-08-2009, 05:13 PM   #7 (permalink)
damnit when I get the aeromod bug i get it bad
Gave the wagon a haircut...
before
after
that should help a touch
Phil
Old 05-08-2009, 08:19 PM   #8 (permalink)
philip1 , Welcome from me as well.
Good to see you are having a go there.
Don't hold back. I am very interested in what you are doing.
Cheers , Pete.
Old 05-09-2009, 01:42 AM   #9 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Nice work! The grille block would probably be slipprier on the outside. You can probably cover the holes in your wheel covers with clear tape or something. The wheel skirts seem like the next step. I'm not sure that the wheel air dams help without a ramp on the leading edge. The nice thing about that is that snow can push flexible ones up even if they are very low. The tough corollary is that fairings behind the wheels will pick up stuff or rip off.
Old 05-09-2009, 01:59 PM   #10 (permalink)
Saturn
The wheel dams ahead of the tires have Cd1.10,not quite as bad as a parachute but close.They need some radius of curvature or its total separated flow and much interference drag downstream.------------- The center of the belly must be squeaky clean or diffuser is a wash.------------ Are you air-tight under the nose,between the fascia and radiator bulkhead?-------------- You already have a Kamm-back.------------- The "basjoos" stuff is the only thing that's really going to show up at the pump.The existing rear overhang of the body makes a boat-tail problematic due to length issues,whereas basjoos Civic didn't have a rear to begin with.Wagons,vans,and SUVs with existing rear overhang makes real drag reduction an extra special challenge
