02-21-2008, 12:51 PM
Corvette V8 diesel conversion - 40 mpg (US) avg.
Some may wonder why I did this - install a 6.5L diesel in a Corvette. To put it simply - fuel economy. Not many cars can handle the weight, is streamlined, won't rust, yet retains its value, and is a sporty - fun car to drive.
I installed the engine in May of 2001, and have driven it about 3000 miles since then. We average about 48-mpg Canadian (40 mpg US), and have seen a high of 55-mpg (46 mpg US).
More info & engine pic: The Diesel Page - Readers' rigs
02-21-2008, 01:50 PM
That VX guy!
That is a pretty genius engine swap...talk about having your cake and eating it too!
02-21-2008, 03:16 PM
Ecomod noob
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry 90 day: 20.57 mpg (US) Neon - '03 Dodge Neon SE 90 day: 33.46 mpg (US) S'Crew - '02 Ford F150 Supercrew XLT 90 day: 16.4 mpg (US) Ranger - '90 Ford Ranger Last 3: 28.02 mpg (US) Not the Jeep - '03 Dodge Neon SE 90 day: 34.11 mpg (US)
Very cool...
When it comes to Heroes, RENEGADES are mine!
02-21-2008, 08:45 PM
I recently saw a diesel conversion of a 5th gen Honda Civic hatchback (the same age as my car), at least I assume it was a diesel converion. It had an official looking Diesel logo sticker in the location where the Civic CX/VX.DX normally is on the tailgate. I'm guessing they had swapped a Rabbit or Golf engine/transmission into the car.
The Following User Says Thank You to basjoos For This Useful Post:
02-21-2008, 09:00 PM
that is pretty amazing mpg for a V-8, even if it is diesel.
2000 Honda Insight 5spd Silver 63.9 lmpg
02-21-2008, 10:14 PM
Camryaro - '92 Toyota Camry LE V6 90 day: 31.12 mpg (US) Red - '00 Honda Insight Prius - '05 Toyota Prius 3 - '18 Tesla Model 3 90 day: 152.47 mpg (US)
They can do better with trans/gearing upgrades.
02-21-2008, 10:16 PM
Good point. I'm not sure what this means... did they upgrade?
We're using a TH700R4 automatic with a manually controlled converter lock-up.
02-21-2008, 10:30 PM
nut
Means it has a .70 4th gear overdrive. And they probably have a toggle switch or something on the dashboard to lock the torque converter.
700r4 is basically the older non electronic controlled version of what GM is using in current cars. I would guess it has 2.73:1 rear end ratio plus the .70 overdrive and probably 225-70/15 tires so it does pretty low rpms at highway speeds.
The Following User Says Thank You to Coyote X For This Useful Post:
02-21-2008, 11:12 PM
#9 (permalink)
According to that guess it's still at around 1250rpm@55mph. Good for a 4L engine, but still kinda high for a 6.5L lump. With something like 6+L idling down the highway at 55mph is probably the best bet.
02-22-2008, 06:08 PM
#10 (permalink)
after reading that id be curious to see how the 6.2 diesel would do , or a powerstroke in a mustang
