Old 06-27-2011, 10:22 PM   #1 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.01 mpg (US)
LED interior lights
I recently picked up some LED interior bulbs for my Civic. These things are a nice upgrade. Depending on what type of bulbs your car uses you can get significantly whiter, brighter light with LEDs. This car has two map lights and a dome light, I took some pics of the map lights with the stock incandescent bulb on the driver's side and the LED on the passenger side. These bulbs consist of four LEDs on a small circuit board. Color is cool white.
I also upgraded the trunk bulb. Stock bulb is a little 194. The site I ordered from has oversized replacements with a standard base, so I picked the biggest one that would fit in the bulb housing.
The results are pretty impressive:
BEFORE
AFTER
Both those pics were taken with the camera at the same exposure.
LEDs also use less power of course, and should last a lot longer. The map and dome bulbs for my car were $7 each, and the bulb in the trunk was $12.
Old 06-28-2011, 08:16 AM   #2 (permalink)
Impressive results! may i ask where you bought them? ive had LED bulbs in the past, but they were worse than the original bulbs haha.
Old 06-28-2011, 08:49 AM   #3 (permalink)
No nickname - '17 Chevrolet BoltEV Premiere
Ditto on the where'd you get them! Very nice results. Please share the name brand on the bulb packaging while you're at it.
Old 06-28-2011, 08:52 AM   #4 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Most likely from LED Lights & Accessories - SUPER BRIGHT LEDS which is where I got mine from. Some websites sell adapters that plug into the sockets and just have a pair of wires coming out that allow you to make your own custom setup. I have red leds for when I go on roadtrips so that my passenger can read a map and not screw up my night-vision.
Old 06-28-2011, 09:30 AM   #5 (permalink)
LEDs - underbody kits, cathodes, flexible LED strips, dome lights and eCRATER - online marketplace, get a free online store also have large selections of LED lights for cars, though I'm not sure of the quality
Old 06-28-2011, 09:33 AM   #6 (permalink)
Renaissance Man
Formula413's Avatar
Yes it's superbrightleds.com. As for the brightness, standard LEDs are generally not as bright as incandescents, but the bulbs I purchased use high power LEDs, grouped together on a mini circuit board, which allows them to actually have greater light output than the incandescents they replace.
Old 06-28-2011, 09:53 AM   #7 (permalink)
dealextreme.com, ledlight.com and sourcingmap.com are a few others that have car LED bulb assemblies, again, not sure about quality.
Old 07-09-2011, 09:11 PM   #8 (permalink)
Silverfox - '05 Honda Civic HX
90 day: 46.08 mpg (US)
LEd's never burn out they just get dimmer over time. So you should have a great light well beyond the years you own the vehicle. Great investment!
Old 07-10-2011, 12:48 AM   #9 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Well some times they just burn out but most will run for years.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 07-19-2011, 04:06 PM   #10 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
I am a fan. Always get SMD type led's when you upgrade your bulbs and you won't be disapointed. They are much brighter than standard. They are flat and yellow faced (like the ones formula used). They look a little funny and cost more but they sure are bright!
